Old 08-25-2013, 11:27 AM   #1
43687269734F's Avatar
1963 16' Bambi
Ann Arbor , Michigan
What type of pump is this?
I don't understand this setup, seems to be a DC pump, but the outlet and inlet (if that's correct) are connected to each other? And then going to the fill pipe for the water tank. [Hopefully two pics attached].
Any chance this is an air compressor instead? If so, how does that actually work?
Thanks!
'63 Bambi
ID:	194099   Click image for larger version
-Chris O
43687269734F is offline   Reply With Quote
Old 08-25-2013, 12:06 PM   #2
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
It really looks like an air compressor with the Tee connected to a pressure switch. There was a time when the fresh water tank was pressurized to provide flow at the tap. Have to assume the way it worked was after the tank was filled, the inlet valve was closed and the compressor was switched on to maintain a pressurized system.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 08-25-2013, 12:16 PM   #3
1994 30' Excella
Mississauga , Ontario
Definitely an air compressor.
Al
Al and Jean
TAC ON-3
Old 08-25-2013, 01:51 PM   #4
1963 16' Bambi
Many thanks everybody.
-Chris O
Old 08-25-2013, 02:30 PM   #5
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Yep.
Pressurized tank fresh water system.
Fill the tank with water, then compressor them kept the tank and plumbing pressurized to push water to the faucets.
The system of choice before modern water pumps were as reliable as they are today.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-05-2013, 09:42 PM   #6
tbirds255's Avatar
Tujunga , California
I have something similar in my trailer, my question is can it be replaced with a regular water pump?
tbirds255 is offline   Reply With Quote
Old 10-05-2013, 10:46 PM   #7
1974 Argosy 20
Kooskia , Idaho
Yes, just use the pipe from the bottom of the tank and run it to the inlet of the new pump. Connect the other end to the pump outlet, connect the power and you will be good to go. It is a simple conversion.
