Old 07-10-2016, 09:25 AM   #1
Gdickison's Avatar
1969 31' Sovereign
Orangeville , Ontario
What is this?
A friend of mine has just purchased a 1976 Land yacht Sovereign with the rear twin bed and curb side bath. Under his kitchen sink is a water pump which draws from his under-floor fresh water tank. At the front of the trailer is a silver painter box which contains ancient looking brass plumbing fixtures which connects to a grey hose into the front of the trailer behind the gaucho at which point it meets what appears to be another pump. This pump is not connected to anything. What is this set up used for, is it necessary, original or aftermarket??? Any thoughts would be appreciated.Click image for larger version
Name:	ImageUploadedByAirstream Forums1468164286.859402.jpg
ID:	266369Click image for larger version
Name:	ImageUploadedByAirstream Forums1468164315.511105.jpg
Gdickison is offline   Reply With Quote
Old 07-10-2016, 10:01 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have 2 guesses:
1. Optional or aftermarket hydraulic brake unit.
2. Although I have never seen one, in the early 70s there was an option called a "Porto San" which (not PC today) pumped the black tank into the tow vehicle engine exhaust manifold as you drove down the road.
Old 07-10-2016, 10:30 AM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Does that add any additional horsepower as did Buick and Oldsmobiles "rocket fuel" did?
yuck!
Old 07-10-2016, 12:08 PM   #4
Trnpk Crsr's Avatar
Baltimore , Maryland
I'd go with the Porto San. The 70's disc brake option had a vaccum booster and a master cylinder just like the one that cars and trucks use.
Trnpk Crsr is offline   Reply With Quote
Old 07-11-2016, 11:10 AM   #5
Gdickison's Avatar
1969 31' Sovereign
Thanks all! I'll pass your suggestions along! My 1969 AS doesn't have one, and I didn't know anything like that existed. Much appreciated.
Old 07-11-2016, 12:28 PM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
That is a vacuum assisted hydraulic disc brake activator. I had one in my 1977 Sovereign. You had to hook a vacuum line up from your truck or car to operate it. The disc brake calipers on my trailer failed and I replaced them with std. electrical brakes. I discarded the activator system. I was a pain to maintain. Very few dealers knew how to fix it and finding parts was impossible.
Old 07-11-2016, 01:22 PM   #7
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
That's pretty good, only four responders in and you got your answer.
There is such a wealth of information here.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-11-2016, 01:31 PM   #8
Long Island , New York
I almost bought a used AS in the early 90's that had a vacuum assist braking system. The tubing at the tow vehicle's carburetor/manifold area was interesting.
Out of curiosity, would it even be possible to rig up such a system to today's computerized engines?
Yes, an amazing wealth of knowledge here indeed . . .
Old 07-11-2016, 02:37 PM   #9
1977 31' Sovereign
1989 34' Excella
New assisted brake systems are electric over hydraulic, using an electric motor to run the hydraulic pump. The old system worked of manifold vacuum and needed a reservoir tank in the trailer, so it would work when manifold vacuum was not present at the moment. When it worked, it worked well, but I got stuck on the road with it too often and when the caliper weldments failed no parts were available.
