Originally Posted by BillTex
Is there water in the tank?
If not, the pilot will extinguish before it gets too hot...
Fill with water, open the pressure relief valve to be sure it is full, the re-light.
Bill
I definitely have the tank filled. I didn't want to even touch the WH until I knew the whole plumbing system was A-ok and the WH full. As far as pressure relief valve, I didn't know you ever had to mess with that. Is that the one upper-right, above the burner unit? Not the drain valve at the bottom left, BillTex?
 So...you bought a vintage trailer, did you, honey? Good deal, was it? Oh, just a couple of repairs, huh?
Drat, now our little Argy is starting to grow on me. I guess you were...were...were...right, honey.
