Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 04-21-2008, 07:14 PM   #15
OregonArgy's Avatar
Profile:  1978 Argosy Minuet 6.0 Metre
Gresham , Oregon
Originally Posted by floyd garver
Is there a chance that you over tightened the thermo coupling ? I usually tighten them just past snug.
I had no idea one could over-tighten. I am sure that I tightened and then tightened some more. I'll be going back in there because I will be soaking the pilot tube. Should I loosen that back up and then only tighted a little. Thanks for that heads-up, Floyd.
So...you bought a vintage trailer, did you, honey? Good deal, was it? Oh, just a couple of repairs, huh?
Drat, now our little Argy is starting to grow on me. I guess you were...were...were...right, honey.
OregonArgy is offline   Reply With Quote
Old 04-21-2008, 07:17 PM   #16
OregonArgy's Avatar
Gresham , Oregon
Originally Posted by BillTex
Is there water in the tank?
If not, the pilot will extinguish before it gets too hot...
Fill with water, open the pressure relief valve to be sure it is full, the re-light.
Bill
I definitely have the tank filled. I didn't want to even touch the WH until I knew the whole plumbing system was A-ok and the WH full. As far as pressure relief valve, I didn't know you ever had to mess with that. Is that the one upper-right, above the burner unit? Not the drain valve at the bottom left, BillTex?
Pingbacks are On
Corroded Burner BambiII'64 Water Heaters, Filters & Pumps 3 03-05-2008 08:40 PM
Help, Burner Timing Out The Flintstones Water Heaters, Filters & Pumps 2 11-17-2007 10:32 PM
Help ! In need of a burner tube. C Johnson Stoves, Ovens & Microwaves 10 10-25-2006 10:32 PM
fridge burner mizzen Our Community 1 08-05-2004 11:41 AM
HELP ! Need burner pilot 74SovereignInt. Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-08-2002 07:41 AM
SEO by vBSEO 3.1.0
