Old 11-26-2013, 12:49 PM   #15
Hadassah's Avatar
1966 30' Sovereign
port o connor , Texas
read above, already replaced thermocouple
Hadassah is offline   Reply With Quote
Old 11-26-2013, 02:56 PM   #16
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Sounds frustrating.. If Butane torch heat on thermocouple won't trigger gas to flow, then clearly something else is wrong... Among options could be inadequate gas pressure at tank burner, or possibly link to thermostat, which tells burner control unit that water need to be heated.. Thermostat is separate unit that clips to side of tank, and has wire back to controller... Not sure I'd agree that unit needs to be completely replaced, but you may have reached point where RV service shop or tech is needed to finally diagnose and fix problem.. In my mind, water heaters are "dead" when tank springs a leak or burner unit/chamber gets so corroded or rusty the integrity of burner unit no longer safe..
Condoluminum
Condoluminum is offline   Reply With Quote
Old 11-26-2013, 06:37 PM   #17
sandlapper's Avatar
1993 34' Excella
York , South Carolina
One more thing to try
There is a small vent in the bottom of the regulator at the tanks. Blow some compressed air into it, it has worked for me before.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 12-26-2013, 01:03 PM   #18
Hadassah's Avatar
1966 30' Sovereign
Just a final update: I replaced the gas control valve and it works great now. Glad I didnt have to replace the entire water heater yet. Thanks for all the suggestions!
Water heater pilot takes FOREVER to light KYAirstream LP Gas, Piping, Tanks & Regulators 9 09-07-2011 01:20 PM
How to Light the Pilot in the Oven lcurrie Stoves, Ovens & Microwaves 3 08-01-2011 07:16 PM
Pilot Light Not Staying Lit vhariable Refrigerators 23 07-21-2011 11:58 PM
Suburban oven, pilot light issue mikeandnora Stoves, Ovens & Microwaves 3 06-14-2011 09:28 AM
looking for help with Magic chef oven pilot light jayg Stoves, Ovens & Microwaves 2 06-01-2011 04:18 PM
