Old 10-05-2015, 04:11 PM   #1
Airdreamer
Dreamnair's Avatar
1999 30' Excella 1000
Canyon Lake , Texas
WaterPump Runs but Doesn't Pump
Every year at this time we run into a problem getting our water pump to pump. It runs, and we even try to prime it by adding water through a bypass, but it just doesn't want to move water.
The only time we use the pump is to winterize and the water tank is empty most of the time. Could this have something to do with it?
In the past we've usually gotten the pump to work, but never know what we did to make it happen. When it pumps it pumps fine; it's getting it started that is always the problem.
Any ideas out there?
Dreamnair is offline   Reply With Quote
Old 10-05-2015, 04:20 PM   #2
1994 34' Limited
Round Rock , Texas
On my AS, I have to open a faucet to get mine to prime and pump. Once its pumping, no issues and the pump shuts off when I close the faucet. My boat is very different, its pump picks up immediately, and doesn't need a faucet opened to prime.
Not sure this helps. Good Luck.
txtwin is offline   Reply With Quote
Old 10-05-2015, 04:34 PM   #3
2015 30' FB FC Bunk
Ayer , Massachusetts
Try opening the faucets, it's probably air.
Ted S. is offline   Reply With Quote
Old 10-05-2015, 04:49 PM   #4
Airdreamer
Dreamnair's Avatar
Canyon Lake , Texas
Faucets
I've been opening faucets. Trying them open just a little and then wide open. No real difference.
Old 10-05-2015, 04:58 PM   #5
2015 30' FB FC Bunk
I had the same problem and that worked for me. Did you try the outdoor shower?
Old 10-05-2015, 04:59 PM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
The pump may have lost its prime. Put water in the fresh water tank, a few gallons. On the input side of the pump there may be a filter. Remove the line from the fresh water tank to the filter and put a piece tubing to it. Pore water into that tube till you see water in the filter bowl. Reconnect the fresh water supply line and try the pump with at least one fauset open.
Sitting for a long time the water in the supply line may flow back to the tank causeing the pump to lose the prime.
2004 Excursion 4x4
Old 10-05-2015, 05:15 PM   #7
Airdreamer
Dreamnair's Avatar
Canyon Lake , Texas
[Sitting for a long time the water in the supply line may flow back to the tank causeing the pump to lose the prime.]
I think you're right, but I'm thinking the reason it loses prime is that the seal dries up over the summer. Then when I start working with the pump I get a little water into it and the seal swells up and does what it's supposed to... pump.
Will try again in the morning to see if the theory holds up.
Old 10-09-2015, 05:51 AM   #8
Airdreamer
Dreamnair's Avatar
Canyon Lake , Texas
For a bit of closure, we (actually, my friendly RV repair guy) finally got the pump going again and it works just like it's supposed to. It took him an hour or so to make it happen, but the diagnosis was just as I thought... dry seals. He claims that RV antifreeze actually pulls moisture out of the seals over the winter. Then if I go all summer without using it the seals are shriveled up like raisins (or maybe old donuts).
In any event, de-winterizing will now include partial filling of the water tank and occasional use of the pump just to keep it happy.
Old 10-09-2015, 08:32 AM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The water pump, with good valves, should pull water regardless of if there is air, but not an air leak, in the input line. Centrifugal pumps must be primed. Diaphragm pumps, like the ones in our trailers, are self-priming as long as the valves work properly. If you have to take unusual measures to get your pump to work, you will ultimately have a complete failure, it's just a matter of time.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-09-2015, 09:00 PM   #10
BessieB's Avatar
1997 21' Excella
Carson City , Nevada
So basically, my pump has failed. Correct? It worked all summer until I left for my trip.
BessieB is offline   Reply With Quote
Old 10-10-2015, 07:49 AM   #11
HowieE's Avatar
Images: 12
As a new poster to this tread i am not sure what would cause you to come to that.
Prime the pump.
If there is or was air in the line it will not pick up a prime from the tank. As for eventual failure from what ever reasoning is noted above I have had to prime my pump every time I pump antifreeze while winterizing. The pump will not draw directly from a gallon of antifreeze at floor level and over the sill of the closet. I have to lift the gallon. That has been the case for the last 20 years so I don't think it is an indication of eventual pump failure
2004 Excursion 4x4
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
Compressor runs but needle doesn't move! ericjan2 Classic Motorhomes 6 10-23-2012 04:34 PM
Water pump runs but no water comes out goswick Water Heaters, Filters & Pumps 18 07-05-2009 06:10 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
pump runs, but no pressure? cedboone Water Heaters, Filters & Pumps 1 01-05-2008 08:38 PM
