02-09-2010, 09:15 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
Waterheater replacement '68 Trade Wind
I asked most of this in the main restoration thread for the Trade Wind but didn't get much in the way of response. I am considering replacing the old, non functioning water heater in the Trade Wind with something from this century. Atwood seems to be the manufacture of choice. Options I need help on are:
1) Six or ten gallon? I would think six would be sufficient output wise, but would installation be easier with the ten? Wasn't the original water heater ten gallon?
2) Propane only or propane/electric power? Is it worth the extra cost?
3) Electronic ignition or pilot? Is it that much more work to light? Is one more reliable than the other? Is the electronic ignition type more likely to fail?
Are there other considerations I should know about before hand?
02-09-2010, 09:45 AM
1967 22' Safari
1960 Caravel
Edmonds
Hi Rodney, The original was a ten gallon tank. For the replacement in the Safari I went with the six gallon only because the ten gallon would not fit in the space the old tank come out of. Went with the electronic ignition and have not regretted getting out to light a pilot light. The only thing I would change is not adding the 120VAC heating option. Slow recovery and not worth the extra money(IMO).
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
02-09-2010, 09:55 AM
1972 25' Tradewind
North Vancouver
, British Columbia
My 1972 Tradewind had a 6 gallon heater, so i replaced it with a new Atwood 6 gallon. Easy swap with minimal fuss. The electronic ignition is, in my mind, brilliant. No need to leave the trailer to light the heater. I did go with the electric heat option as well, only because I was camped in the back yard for the better part of a year while my house was being built. This let me reserve propane for cooking and the furnace. I found the 6 gallon to be just fine for me to shower in the morning.
North Vancouver, BC
02-09-2010, 09:56 AM
1963 24' Tradewind
Anderson / Sun City
, Indiana / Arizona
water heater
I have a 1963 Tradewind with the side gaucho. I replaced my original Bowen water heater with a 6 gal. Suburban because the Atwood was 1" too tall to fit under the gaucho. The Suburban also has a lined tank.
I originally installed a gas only water heater because that was what the original was, and how hard could it be to light it manually? Well, after a short time, I realized that I had made a mistake to save about $100.00. This initial savings cost me about $350.00 to remedy.
I bought another Suburban water heater, but this time I bought an auto ignition gas/electric model. I find that it produces plenty of hot water for my needs. It is quiet, and I can use electric only when on the grid.
I would highly recommend that you consider the long term convenience of the dual mode models with auto ignition vs. the small savings of a manual gas only.
02-09-2010, 09:59 AM
1972 25' Tradewind
North Vancouver
, British Columbia
According to this brochure:
http://service.airstream.com/files/l...73d453df75.pdf
...yours would have a ten gallon tank, so I think replacing it with the same size would be easier.
North Vancouver, BC
02-09-2010, 10:01 AM
1966 24' Tradewind
Placerville
Our TW had the original 6 gal. I replaced it with the 6 gal Atwood gas/electric and it has met our needs. The water heater recovers very quickly so hot water isn't a problem. The pilot alone keeps the water hot in the times of non needed use. http://www.airforums.com/forums/f445...-in-36653.html
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
02-09-2010, 10:24 AM
1963 24' Tradewind
Anderson / Sun City
, Indiana / Arizona
Atwood vs Suburban
I am curious why there appears to be a bias in favor of Atwood water heaters.
When I researched water heaters 2 years ago I concluded that there was little difference in technology or reliability between the two brands. In my case the Suburban fit better under the gaucho which broke the tie for me. Suburbans also have lined tanks and a cathode rod to deminish corrosion. However, did I miss something?
I did install an Atwood furnace to replace the original International furnace. That decision was based on the fact that Airstream now installs the Atwood furnace, and they are serviceable from the outside.
02-09-2010, 10:32 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
I think I read somewhere that they fit better most the time
02-09-2010, 10:42 AM
1972 25' Tradewind
North Vancouver
, British Columbia
In my case it's because the Atwood was a direct fit with no need to make any alterations to the surrounding millwork or the skin.
North Vancouver, BC
02-09-2010, 11:04 AM
1967 22' Safari
1960 Caravel
Edmonds
Rodney, I reworked the original cover to work with the new style vent on the W/H to keep the vintage look. I'd post picks but it is not as nice as what Scott did here. http://www.airforums.com/forums/f150...tml#post744489. On second thought you might have the flat Atwood cover. There has to be a way to still use that cover to keep the vintage look.
Good luck!
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
02-09-2010, 12:40 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
I just measured the opening for the water heater. Its 20 1/2 X 15 1/2. If I am reading the spec sheet right, either one will fit.
02-09-2010, 03:20 PM
1967 22' Safari
1960 Caravel
Edmonds
The opening was not the problem for me, it was the depth.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
02-09-2010, 04:24 PM
1968 24' Tradewind
Oxford,
, Mississippi
After a lot of thinking and talking, I went with a 10 gallon Atwood electric/propane for my 68 TW. I did make one BIG mistake. When I trashed the old heater, an Atwood, last summer I tossed the cover. Problem was it was a two piece deal with a small door and a bigger cover. Well, the new heater's door is smaller than the opening in my trailer. I am going to have to make a panel to fill in around opening. No big deal, just another item on the punch list.
02-09-2010, 05:26 PM
1966 24' Tradewind
Placerville
If you follow the thread that I posted for you a few back you will see that I used the orginal outer panel to fill the space up to the new door. You should be able to easily adapt an aluminum panel to do the same thing. I was my intention to refit/adapt the original door to keep the original vintage 'look'.......someday
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
02-09-2010, 10:29 PM
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral
02-10-2010, 03:51 AM
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral
When I posted the pictures last night I realized I had none of the outer door in its final form. You will see that I added additional CamLoc's to hold the door tight to the body when closed. That worked pretty well.
