Old 10-23-2014, 09:18 AM   #1
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Water warm, not hot.
Greetings,
Monday we purchased a 2000 19' Bambi and all systems worked beautifully with one exception. We were hooked to shore power and city water and turned on the gas water heater. The light went on briefly, then out and I could hear the water heater fire up. In an hour or two we turned on the hot water, and got a blast of hot water, that immeadiately turned and stayed luke warm. This same scenario for the the two days we camped. I'm not sure if the heater is malfunctioning or if we are getting some cold water mixed in inadvertently. The valves that are in the hatch and next to the water heater are set as follows:
1. top and bottom valves are in the open position, parralel with pipes,
2. one in the middle is in the closed position, perpendicular to the pipe.
questions:
1 Is there another location for valves that I need to check?
2 Is there a test procedure I can go through before bringing it to my local AS guys?
Cameron
curnes is offline   Reply With Quote
Old 10-23-2014, 09:23 AM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Your water heater water line valves are in the correct position for normal operation.
Perhaps a thermostat failure? Try searching online for ways to troubleshoot and if necessary replace your thermostat.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-23-2014, 09:37 AM   #3
Wayward's Avatar
Cary , North Carolina
What you describe certainly does sound like the bypass valve (the center one) is partially open. It sounds like you have it shut however.
There is some possibility that the valve is leaking or not completely closed. You could test it by leaving the cold water input valve open, leaving the center bypass valve off, but shutting off the hot water output valve. In this configuration, you should get no pressure at all from a hot water tap in the Airstream. If you do, the center bypass valve is leaking.
Another possibility is sludge build up in the bottom of the tank, slowing heat transfer from the bottom of the tank (where the flame is), to the water. This can cause the tank to get very hot but not the water so much. There is a plug in the bottom of the tank. You could pull it and see what comes out.
I would try those first and then look at the thermostat.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-23-2014, 10:44 AM   #4
curnes's Avatar
Tin Tin, Wayward- you guys rock. I will drain the tank, and try the valve test. This is just what I was looking for. Cameron
Old 10-23-2014, 11:08 AM   #5
2006 19' Safari SE
Hayes , Virginia
Water Heater
Stick with these guys (gals) on the forum...they will keep ya pointed in the right direction.
mocus is offline   Reply With Quote
Old 10-23-2014, 12:15 PM   #6
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Did you bleed the air out of the tank?
Do it with water pump on and water heater off.
Make sure it has time to cool down first then lift pressure relief handle on hot water tank.Let out the air until water flows out.
Old 10-23-2014, 02:52 PM   #7
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Actually you should fill the HW tank with the pressure relief closed. You want some headspace in the tank.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 10-23-2014, 09:53 PM   #8
curnes's Avatar
Thanks again for all the replies. I drained the tank and the water was very clean. I then checked the valves and found the middle valve was not closed all the way, so hand tightened it and presto, everything is copacetic. Hot water. Man, these airstreams are really cool.
Old 10-24-2014, 08:17 AM   #9
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
You had me thinking hard on this one... It was like, "HOW could there not be at least six gallons of hot water in there?" Glad you found it. And, yeah, these things a pretty stinking cool! Enjoy!
-Red
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 12:58 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
New NT30 is NOT keeping us warm!! obxgal Furnaces, Heaters, Fireplaces & Air Conditioning 10 12-20-2009 12:28 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
