Old 11-27-2009, 11:06 AM   #1
2005 28' International CCD
Camarillo , California
water pumps
any thoughts on what make/model water pump is the quietest, most reliable?
loft47 is offline   Reply With Quote
Old 11-27-2009, 11:10 AM   #2
The best, most reliable and quietest if made by Jabsco.
But it is also the most expensive.
They are known to last 30 to 40 years.
t1
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-14-2009, 10:36 AM   #3
adwriter73's Avatar
2005 16' International CCD
What about Shurflo? I need to replace mine too. Looks like I have the Jabsco model, which seems like it would be an easier switch out. But I see more and more people installing the Shurflo Extreme Series. It's half the price of the Jabsco? Thoughts?
adwriter73 is offline   Reply With Quote
Old 12-14-2009, 11:24 AM   #4
There are repair kits available for your original water pump, that should make it last another 30 years or more. The kits are not cheap, but more than likely, in the same 30 year period, you will need to but several Shurflo's, which will cost more than the kits. At least with the kits, you also have a quiet pump. Not so, with the Shurflo.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-14-2009, 11:58 AM   #5
Mexray's Avatar
1978 28' Ambassador
Morada , California
I installed a variable-flow model - it doesn't use a pressure switch, and runs at different speeds depending on how much you open a faucet...fairly quiet, as well, depending on how well you insulate the mounts...
Several Mfg's make these variable-flow models...I got ours from West Marine, it's their house brand, but is probably made by one of the major 12 volt water pump mfg'ers, Jamsco, Sur-flo, etc...
The one problem I've had with 'rebuilding' older pumps, is with the electric motor itself - sure you get the wearable pump parts with the rebuild kit - but the motors do wear out as well; bushings, commutators, and carbon brushes - and by the time you have to invest in a complete motor, along with the rebuild kit, you might as well purchase a whole new pump to update your system...IMHO
Ray & Pat; Morada, CA
Old 12-14-2009, 05:59 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Both of our trailers have Shurflo "Whisper King" pumps. Work well and are nearly silent when installed with a loop in the outlet hose.
Old 06-12-2010, 11:18 PM   #7
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Anyone else have some pump recommendations?
I just got back from my maiden voyage and had the horrible experience. I had to manually cycle from full hot to full cold as best I could stand it to finish. Any less pressure as a middle and mix position would cause jackhammering and minimal water pressure. What's up with that? Anyway DH thinks replacement would be a good choice for quiet operation and perhaps a few other beneficial upgrades to newer models. Ours is a 2004 built in 2003, not sure off hand the model pump installed. Sink baths were in order after that sequential scald/freeze diving in a cold lake after sauna type experience.
Caroljb
photography
wheel interested is offline   Reply With Quote
fuel pump location? jagcb750 Classic Motorhomes 17 12-17-2010 12:57 PM
Sewer fixtures for black/grey water pumps beerrun'r Waste Systems, Tanks & Totes 0 02-27-2009 01:40 PM
Mid 60s Water Pumps mountaindove Fresh Water Systems 10 09-16-2007 06:12 PM
Water Pumps, Hydroboosts and Automobiles swebster Mechanics Corner - Engines, Transmission & More... 32 02-19-2006 09:43 PM
Fuel Pumps 85/345 Mechanics Corner - Engines, Transmission & More... 2 12-13-2004 07:21 PM
