Old 01-24-2018, 09:58 AM   #1
Sphere Guy's Avatar
Livingston , Texas
Water pump woes, AGAIN
Well, Our 2nd water pump has begun filling the fresh water tank.
I took apart the 1st one and checked the check valve. Didn't help. replaced it Oct 2016 with a new one. Went to factory in May 17 and they reimbursed me for the cost but not labor. A good deal.
Now Jan 18, it began again after filling the tank in case the park's water froze. Then it started filling the tank again. This is after another AS in the park, a 2017 30 Bunk had the same issue.
Well, I tried flushing the valve multiple times. No luck. I didn't want to change the pump again. So I installed a Shark Bite check valve in line and tested. Seems to be fine. Tanks level staying the same.
My buddy with the 30 Bunk is not so lucky. He doesn't have enough room in his line to install the 2 1/2" check valve.
What's with these Shurflow pumps? The internal check valve design is not holding up IMHO.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 01-24-2018, 11:30 AM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
Quick question, does this happen while connected to city water???
I have several AS that will fill/overfill the fresh water tank while connected to city water AND the water pump switch on. It is kinda convenient when you want to dry camp after being connected to city water, I just turn on the pump and a couple hours later the fresh tank is full!
vintagemotor is offline   Reply With Quote
Old 01-25-2018, 08:07 AM   #3
Sphere Guy's Avatar
Livingston , Texas
Yep, it happens when connected to city water and with the pump off. I’ve never had the pump on when connected to city water, except when trying to flush the check valve to have it stop filling the fresh water tank.
Sphere Guy
AIR 50601
Old 01-25-2018, 08:58 AM   #4
suzieleigh's Avatar
2006 31' Classic
Wendell , Massachusetts
Call Shurflo and they'll tell you how to make an adjustment and fix it. It happened to our pump so I called them and they were great.
suzieleigh is offline   Reply With Quote
Old 01-25-2018, 09:05 AM   #5
Sphere Guy's Avatar
Livingston , Texas
Thanks, Ill try that. But the Shark Bite check valve seems to have stopped it for now.
Sphere Guy
AIR 50601
Old 01-25-2018, 09:06 AM   #6
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
May be the backflow valve protecting the fresh water tank from the black water flush system. Found behind the sink area. A plastic valve prone to cracking.
jkcru is offline   Reply With Quote
Old 01-25-2018, 09:52 AM   #7
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Sphere Guy,
We're sorry to learn about the issue with the water pump that you described in your 2016 30' Classic. Please call our customer service and technical support team at*1 (877) 596-6111, option 2 so we can learn more and help.
Thanks.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 01-25-2018, 10:30 AM   #8
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Not sure what pump you have, the OEM one? I had pump issues and my Airstream dealer tech said the OEM pump was junk and to replace it with this one
No problems since.
jtwind is offline   Reply With Quote
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
Logging In Again and Again and Again Secguru Forum Admin, News and Member Account Info 4 11-01-2010 12:15 PM
Grievance time again -Leo gets slammed again LI Pets WBCCI Forum 47 12-23-2009 02:02 AM
Murphy's Law Strikes Again and Again . . . . . . overlander64 Our Community 5 04-22-2003 12:53 AM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-02-2002 12:03 AM
