Old 12-13-2008, 01:28 AM   #1
1975 Argosy 24
oakland , California
Unhappy Water Pump Vomits water out of faucets!
Hi Everyone,
I am new to the Airstream lifestyle and I recently just moved into my Airstream Argosy 1975 24' trailer.
Among other quirks I discovered, the water pump is now sputting and seems to almost vomit (forgive the crude description) water out in big spurts and struggles to get the spurts out. It wasn't doing this before, but I've had a couple of weird issues with this pump, this is the latest.
is this something that I can fix or is it time to invest in a new pump? (although this one is brand new only a few months old).
Thank you!
thoreaulycra is offline   Reply With Quote
Old 12-13-2008, 04:47 AM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Sounds like air trapped in the lines, not familiar with your model but when we got our Classic the WP was the first thing to fail.(on our first trip). I had to prime the new one after install. Hope thats all it is.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-13-2008, 05:24 AM   #3
SteveH's Avatar
Common Sense , Texas
The water pumps are nothing more than some diaphrams (the older model just one diaphram) and check valves, and if some foreign mater gets stuck in one of the check valves, the result will be simular to what you discribe. Almost all of them can be disassembled and checked, and this is what you may want to do in the effort to save replacing it again. I would also check to see if there is a filter installed before the pump, and if there isn't, I'd put one in there. Good luck.
Regards,
Steve
Old 12-13-2008, 12:06 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If it sputers, it usually means there is an air leak on the vacuum side of the pump. Check by tightening all the hose clamps and seals on the filters you have before the pump. If it is old pump with the non-direct drive motor with the pulley, think about replacing it with a FlowTec, or equivalent, direct drive one for about $70 and you will be much happier with the reduced noise and improved performance. It takes about 15 mins. to install the new one. Make sure you have a flexible hose connected to inlet and outlet to assure even less noise.
Old 12-13-2008, 12:23 PM   #5
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Originally Posted by thoreaulycra View Post
Hi Everyone,
Thank you!
Great visual image.
The pump should prime with no problems due to the placement of the tank and pump. I would check all of the clamps and make sure you're not sucking air. The third thing is the pump is 33 years old if it is the original. Probably time for a new one.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-19-2008, 11:12 PM   #6
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
Darrington , Washington
all good advice, burping is air in the line that is locked at a high point until the water pressure builds to overcome the blockage. So firts look for high points in lines, etc. If the piping is copper you wont see thru it but if it is PEX colored whte you might take a strong light and look for bloackges. If you have a leak in the inlet side of the pump, it will continue to have air. Have you tired hooking shore water and looking for leaks?
Good luck
buffaloman is offline   Reply With Quote
no water from curb side faucets lefthandtim Plumbing - Systems & Fixtures 6 10-06-2008 05:37 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
HELP-No water in any of the faucets??? shinybean Fresh Water Systems 10 11-23-2006 09:14 PM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 04:45 PM
Water faucets otha1 Sinks, Showers & Toilets 5 08-31-2003 10:05 AM
