Old 03-18-2015, 06:07 PM   #1
1975 31' Sovereign
san Antonio , Texas
Water pump tie in?
Ok, so we are working on getting our water operational in our 75 sovereign center bath. Loos as though we are going to be replacing most all of our copper with pex. There is a problem we came across today.... Our water pump is not tied in to any of the water lines and there are no loose water lines. I was hoping someone could help me out and point me in the right direction. Any help would be greatly appreciated.
Kiera is offline   Reply With Quote
Old 03-18-2015, 07:17 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The suction side (the side with the clear plastic filter) should go into the fresh water tank to let the pump draw water.
The outlet side should go to a cold water line.
add edit: before taking time to plumb it in, check to make sure it works. If it is the original pump it is likely that the diaphragm is cracked.
Alan
A W Warn is online now   Reply With Quote
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
hook ups for water tank , pump and tie ins batt Fresh Water Systems 3 10-03-2010 07:10 PM
Ok cant find info on Propane tank tie down? Mrcrowley Exterior Restoration Forum 2 11-28-2008 09:10 PM
Tie House & Coach Batteries for Winter Storage? N2XBW Electrical - Systems, Generators, Batteries & Solar 5 11-23-2007 10:29 PM
Awning tie downs? docbluedevil Awnings 6 04-10-2004 07:56 PM
