Old 10-11-2010, 02:13 PM   #15
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Originally Posted by Pahaska View Post
..... Radio Shack has 12v LEDs with the resistor built in at reasonable prices.
Don't mean to hijack this thread, but guess I am. What do you mean
"with resistor built in"? I just ordered a 12v green led for a water-pump-ON
indicator. I was planning to hook it in parallel where the 12v power line enters
the pump. Whats this resistor stuff?
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 10-11-2010, 03:38 PM   #16
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
LEDs are available with or without a built-in dropping resistor. If you hook one without a resistor directly to 12V, you get exactly one very bright, but very, very short burst of light. The Radio Shack LEDs have the resistor built in so that you can tie them in to any 12V circuit without any other component required.
I have some LEDs without resistors as telltales for other switches in my trailer. For each of these LEDs, I used a resistor from my parts box to limit the current.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 10-11-2010, 04:20 PM   #17
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Switches that light up when "on" can be purchased in various colors at most auto parts stores. Most are "rocker" switches, which are nearly flush when installed.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 10-11-2010, 05:07 PM   #18
Pahaska's Avatar
Hays County , Texas
They work fine, but it is better to use the existing switch with a LED whenever possible. Both of my water pump switches, for example, are integrated with other switches or built into my monitor panel.
Also, the water pump in most models is controlled by a 3-way circuit with switches in the bathroom and galley. The LED must be installed at the pump or after the last 3-way switch. Mine is installed on the monitor panel which is the last switch in the circuit.
John W. Irwin
WBCCI #9632
Water Pump and switch wacnstac Water Heaters, Filters & Pumps 2 07-25-2010 01:00 PM
Pump Switch Wiring lewmad Water Heaters, Filters & Pumps 13 09-30-2009 09:27 AM
'65 caravel galley pump switch cosmos Fresh Water Systems 6 07-22-2009 07:06 AM
Pump Switch Chaplain Kent Electrical - Systems, Generators, Batteries & Solar 1 06-28-2004 07:39 AM
water pump switch wheel interested Water Heaters, Filters & Pumps 1 12-11-2003 09:46 PM
