Old 05-23-2011, 03:34 AM   #1
darryl97420's Avatar
1974 Argosy 28
Coos Bay , Oregon
water pump slow to cycle off
Greetings,
Recently I have noticed that the water pump in my 74 Argosy28 will run another 10 to 15 seconds after the faucets are turned off This started not long after I ran the water tank empty.
Any suggestions?
darryl97420 is offline   Reply With Quote
Old 05-23-2011, 04:53 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Run all the faucets a bit to make sure there isn't air in any of them.
Old 05-23-2011, 06:49 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I agree. Air in the lines will compress quite a bit more than water, and that will make the pump take longer to cycle off. You may need to run the hot water for several minutes to purge air out of the water heater.
Chris
Old 05-23-2011, 07:04 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Water Heater
Bleed the air out of the water heater by lifting the lever on the pressure relief valve.
Old 05-23-2011, 07:39 AM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
You may have insufficient flow from the pump to properly get rid of all the air; hooking up to city water will help in that case. Bleed the air from the lines as you'd bleed your brakes - start with the faucet/tap closest to the pump (in terms of plumbing runs) and work towards the furthest. Don't forget to open the drain taps as well; they might have some dead end runs that could retain air.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Interstate coach water pump problems solar-guy Sprinter and B-van Forum 10 06-03-2015 02:51 PM
No water from pump Castaway Fresh Water Systems 10 04-13-2011 08:59 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
