Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 08-19-2009, 10:33 AM   #1
craftsman's Avatar
Profile:  2007 25' Classic
Bath , North Carolina
Water Pump Runs Continuously
Just discovered my water pump is running continuously. This must have just started because I was in it just yesterday and it wasn't running. Also turned on the water and the pressure seems a little low. Any ideas as to what would cause this?
Jack Palmer
craftsman is offline   Reply With Quote
Old 08-19-2009, 11:03 AM   #2
Profile:  2007 30' Classic
Leonardtown , Maryland
Make sure you have water in the fresh water tank. If so, then look for a broken hose. Pump will stop when it has back pressure. Without water it will not turn off.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 08-19-2009, 12:15 PM   #3
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
Also if the pump has water and still won't turn off, it could be bad. Depending on what type of pump you have, they are either a series of diaphrams or a single diaphram if it is the older type, and they all have check valves internally. If the check valves start leaking, or a diaphram fails, they will run continously.
SteveH is online now   Reply With Quote
Old 08-19-2009, 01:57 PM   #4
craftsman's Avatar
Thanks guys. May be time for a new pump.
Jack Palmer
Old 08-19-2009, 02:05 PM   #5
SteveH's Avatar
San Antonio , Texas
I see you have a newer trailer. Don't know about the new pumps, but you could by parts to repair the older ones. Might be worth a call to a dealer, as they are easy to work on.
Old 08-19-2009, 02:13 PM   #6
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
Unless you have freeze damage, I'd be surprised if your 2007 already needs a new pump. You may have an intake problem like I'm presently having with mine. A fitting on the intake side of your pump may have a crack or even the hose itself. It may also be as simple as tightening down a clamp to ensure an airtight fit.
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Water pump runs but no water comes out goswick Water Heaters, Filters & Pumps 18 07-05-2009 07:10 PM
Water Pump Vomits water out of faucets! thoreaulycra Water Heaters, Filters & Pumps 5 12-20-2008 12:12 AM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 03:01 PM
pump runs, but no pressure? cedboone Water Heaters, Filters & Pumps 1 01-05-2008 09:38 PM
68 water pump-should the pump cycle? Gen Disarray Water Heaters, Filters & Pumps 8 08-06-2006 11:11 AM
