Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 07-03-2009, 07:58 PM   #15
Profile:  1968 26' Overlander
Durham , North Carolina
Thanks for the information about rebuilding the water pump. If it is that easy maybe I'll give that a try as well. Where did you get the kit?
Pete
goswick is offline   Reply With Quote
Old 07-04-2009, 09:17 AM   #16
Profile:  1976 Argosy 24
Ligonier , Pennsylvania
Pete
I got the kit from iboats.com (need the www. in front) for the purpose of this post did not want their ad form to pop up. The kit came in a blister pak, all parts including push rod. If in doubt they have tel no for inquiry.
Cost with shipping under $100.
Just be sure to pick the right kit for your pump model. I'm sure it is available from camping/trailer suppliers as well.
Good luck.
Don't force it! Use a bigger hammer!!!
ls99 is offline   Reply With Quote
Old 07-05-2009, 02:16 PM   #17
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 12
Your water flow should be almost as good as the average campground system. If it is not I would look into Andy's suggestion of a rebuild kit to make sure the pump valves are not leaking back to the tank and reducing the pressure.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-05-2009, 05:42 PM   #18
Profile:  Tyler , Texas
I have been reading and reading trying to find someone that has found a cure for my problem. It matters not whether I am on city water or on the pump I get a surge of water when I first turn on the faucet and then it reduces to a slow stream. This is in the shower. bath and kitchen. I have cleaned all filters and screens that I have with no results. I detached the hose from the pump and tried to blow with a compressor but I seem to have a restriction somewhere....or maybe a valve that I have not found.Seems the system needs some Avidar! HELP86 345Pete
pjude is offline   Reply With Quote
Old 07-05-2009, 06:10 PM   #19
HowieE's Avatar
Images: 12
Yes you do have a restriction. Any time the initial flow is high and then drops off that is a classic indication of a restriction.
Not sure what year your trailer is but if it is old enough to have copper pipe I would look for a bent pipe that has almost collapsed. If the problem is only on the hot water side I would look at the connections at the rear of the heater for a build up of calcium across the pipe. If it effects both hot and cold you are just going to have to cut into the system at different points until you are past the restriction and replace some piping. There is most likely some foreign matter in there.
Water Pump Vomits water out of faucets! thoreaulycra Water Heaters, Filters & Pumps 5 12-19-2008 11:12 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
pump runs, but no pressure? cedboone Water Heaters, Filters & Pumps 1 01-05-2008 08:38 PM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 04:45 PM
Water Pump running, water is not... CampSayler Water Heaters, Filters & Pumps 4 09-23-2004 04:34 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
