Old 09-12-2012, 07:30 AM   #1
Water Pump replacement recommendations
Does anyone have a recommendation for a pump and motor other than the sureflo? Not that i have reservations about the pump but wondering if their are some better options. this pump is to be housed in a 1992 excella 29 ft.
jimmyroy is offline   Reply With Quote
Old 09-12-2012, 10:29 AM   #2
dznf0g's Avatar
Oswego , Illinois
I really like the new variable speed Shureflos. The AS had a flowjet in it as OEM and It failed after little use. Ive had my sureflo for 2 years and it has been flawless.
-Rich-
Old 09-12-2012, 03:43 PM   #3
2005 19' Safari
GLENDALE , AZ
Link to freshwater pumps: Plumbing - Freshwater Systems - Freshwater Pumps - 12V at West Marine
Note: Above is for reference only. I have no experience with any of these pumps, and other brands and sources may better fit your needs and wallet.
Old 09-12-2012, 03:52 PM   #4
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I replaced ours with a Sureflo WhisperKing, it's so quiet I wasn't sue it was working at first.
Very straight forward change.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 04-24-2013, 10:19 AM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
What gallons per minute spec should be used? I see the Whisperking is 2 gal/min. Is that enough or should we look for 3 or 4 gal/min. Maybe the higher pressure models are noisier.
Kelvin
