Old 11-12-2010, 08:54 AM   #1
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
water pump recommendations?
I need to replace the water pump on my 1960 Traveler. There are several available on e-bay but I'm not sure what brand is best, how many amps, gmp, etc.
Can anybody recommend a good one that won't bankrupt me more than this little trailer already has?
lucymcdog is offline   Reply With Quote
Old 11-12-2010, 09:08 AM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
You'll need to figure out if you have the original water tank (they came either galvanized or aluminum) OR if it has been replaced. If it's original, you likely have a pressurizing pump. If the tank has been replaced you likely have the kind of pumps you can get on ebay. A photo of the tank and pump would be helpful.
Good Luck.
MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 11-12-2010, 04:43 PM   #3
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
It had the galvanized tank that looked like a torpedo. We have taken it out and will be putting in a new tank.
Is any brand better than another?
Old 11-12-2010, 06:05 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I put a Shurflo in my TW and it works well. PPL had a good price on it.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-12-2010, 07:30 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
ShurFlo Whisper King.
We have one in each trailer. They work very well, and are nearly silent.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Cycling Water pump with no water leaks TheProfessor Water Heaters, Filters & Pumps 4 03-30-2010 06:54 PM
Recommendations For Water Tank Size, Help! erikjware Fresh Water Systems 3 05-08-2008 02:14 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Water Pump Recommendations COArgosy78 Water Heaters, Filters & Pumps 3 06-25-2004 01:27 PM
