Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 07-24-2008, 07:50 AM   #1
daanderson
daanderson's Avatar
Profile:  1973 25' Tradewind
New Smyrna Beach , Florida
Water Pump Question
I have a 73 tradewind. My water pump stopped working yesterday. The light comes on on the control panel but nothing. My pump, located under the sink is an old pully and belt type. Am I looking at the right thing? I checked the fuse and it's good. Any suggestions?
daanderson is offline   Reply With Quote
Old 07-24-2008, 08:20 AM   #2
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Check the belt first to see if it jumped off. If the belt is OK use a test light or volt meter to see if you have 12 volts across the 2 wires at the pump when it is on. If you have voltage not sure if you can get to the pressure switch to jumper it out. If you can jumper out the pressure switch and still don't have a pump its time for a new pump.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-24-2008, 08:44 AM   #3
flashbackk
Profile:  1974 31' Sovereign
flint , Michigan
Mine has a second fuse located behind the control panel also. I won't tell you how long it took me figure that out either.
flashbackk is online now   Reply With Quote
Old 07-24-2008, 08:47 AM   #4
ticki2
Profile:  1976 25' Caravanner
Campton , New Hampshire
The 2 wires that feed the pump from the switch have bullet connectors on them near the pump , make sure they are both connected.
ticki2 is offline   Reply With Quote
Old 07-24-2008, 08:55 AM   #5
daanderson
daanderson's Avatar
Thanks Guys! It was working fine and just stopped. I'll be busy tonight checking everything out. Hope it's a simple fix but if it's like the boat, cha-ching!!!
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
water pump question rama777 Water Heaters, Filters & Pumps 5 10-26-2006 09:47 PM
68 water pump-should the pump cycle? Gen Disarray Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Water pump question jimlegs Water Heaters, Filters & Pumps 7 11-05-2005 08:21 AM
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 12:12 PM
