Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 10-26-2006, 06:24 PM   #1
rama777
Profile:  1974 31' Sovereign
jemison , Alabama
water pump question
I'm redoing the plumbing in my newly baught airstream. When I use hot water, will the pump pull water all the way to the back where the water heater is? Thanks!
rama777 is offline   Reply With Quote
Old 10-26-2006, 06:36 PM   #2
jimmickle
jimmickle's Avatar
Profile:  Marion , Iowa
Yes. If you find the pump too noisy, you should consider one of the variable speed ones. We love ours.
jimmickle is online now   Reply With Quote
Old 10-26-2006, 06:43 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
Probably not. What size is the suction line, and what type of pump?
Non-contributing deadbeat.
Old 10-26-2006, 07:28 PM   #4
ticki2
Profile:  1976 25' Caravanner
Campton , New Hampshire
The pump should only be pulling water from the tank to the pump , after that it is pushing . If it is working properly it should feed everything including the shower , both hot and cold .
ticki2 is offline   Reply With Quote
Old 10-26-2006, 10:10 PM   #5
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
Right. My pump puts out about 40 psi. This gives plenty of water thru the whole coach. Unless "Mister Stupid" forgot to put the plug back in the city water connection.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 10-26-2006, 10:47 PM   #6
markdoane
Images: 59
Don't understand why you want to put the pump back by the water heater. Is it a wiring problem?
Normally the pump would go next to the tank, and push water to the water heater, rather than pull it. Like Ticki2 said.
pump not working... Chuck Water Heaters, Filters & Pumps 23 05-16-2007 10:44 AM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 09:28 AM
water line leak Bugsy1082002 Plumbing - Systems & Fixtures 5 10-30-2002 08:27 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 07:52 AM
Flushing Black Water Tank 1985air345 General Motorhome Topics 3 05-16-2002 03:59 PM
