Old 03-27-2011, 07:37 PM   #15
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Originally Posted by HowieE
cut the end off the hose and get a band strap hose clamp and see if you can tighten it down enough to seal to the filter.
If not not get a small dia hose.
OK, that's a plan. More news after success! Thanks
Sent from my iPad2 using AIR Forums
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-31-2012, 10:33 PM   #16
Roblin , MB.
I installed a new rebuild kit in our JABSCO water pimp (belt driven). Started up and got it's prime but has a good leak around the metal cover plate on the bottom.
Screws in the metal plate were tightened well.
Anyone run into this before with a Jabsco pump? I'm not a pureist but thought it would be nice to keep this pump operating a few more years.
Would a solution be to cut out a gasket to fit from bulk gasket material and place under the metal cover for a more positve seal?
nairnchyz is offline   Reply With Quote
Shurflo Water Pump Problem mello mike Water Heaters, Filters & Pumps 15 08-20-2009 12:32 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Problem Water Pump MattM Water Heaters, Filters & Pumps 3 07-08-2005 12:32 AM
Electrical problem - Water pump, vent hood fan & light Rob30044 Electrical - Systems, Generators, Batteries & Solar 5 11-28-2004 02:38 PM
Water pump problem wayne.yl Water Heaters, Filters & Pumps 4 08-23-2004 09:03 PM
