Old 01-16-2018, 03:28 PM   #1
torrington , Connecticut
Water pump problem
I have 2017 Sport 22 ft. The water pump pumps air and water. I checked all fittings, no water leaks. Tried everything I could think of please help.
frankct is offline   Reply With Quote
Old 01-16-2018, 03:32 PM   #2
Gainesville , Florida
Is the tank empty? Cannot always go by the monitor.
Old 01-16-2018, 03:49 PM   #3
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Have you taken off one of the tubes to the pump. The reason I ask is because I had a similar problem and it was because I did not screw the connection on correctly and air was getting in. Once I realized that and connected properly the pump worked fine
urnmor is offline   Reply With Quote
Old 01-16-2018, 04:13 PM   #4
The tank is full and the tubes are tight
Old 01-16-2018, 04:28 PM   #5
2007 22' International CCD
Unscrew the tube feeding the pump inlet and look inside the end. Unscrew the strainer, and look for the o-ring.
Sometimes the rubber cone gasket in the line, or the strainer o-ring goes missing. The connection will certainly be tight, but will leak plenty of air on the suction side.
Tight is not an indication of proper connection unless the gasket, o-ring, or cone washer are properly in there, and not damaged...
It's so much easier to find leaks on the pressure side...I usually get sprayed with water (sigh).
rmkrum is online now   Reply With Quote
Old 01-16-2018, 05:45 PM   #6
2019 30' International
Pennsylvania , Pennsylvania
You didn't happen to just de-winterize? Some times it takes a while to clear the lines of air. Hook up to city water and run through, then try the pump.
Otherwise definitely do as stated, check the pump lines for proper o rings/gaskets.
majorairhead is offline   Reply With Quote
Old 01-16-2018, 07:06 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
If air is getting in to the pump and there is some water coming too, the options are:
1. loose fitting
2. cracked intake pipe
3. cracked pump head
4. water level in the fresh water tank almost empty
5. semi-frozen water in the fresh water tank
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 01-16-2018, 08:53 PM   #8
kenen42's Avatar
2011 27' FB Flying Cloud
Delmar , New York
I would second rmkrum's suggestion to check the gaskets and seals on the inlet side. I had the exact same symptoms last spring when I de-winterized. Turned out the gasket on the inlet connection to the pump had fallen out without my noticing it. A trip to the big box and 50 cents fixed the problem.
kenen42 is online now   Reply With Quote
Old 01-16-2018, 09:17 PM   #9
CruizinDux's Avatar
Tracktown USA , Oregon
from a recent thread...
http://www.airforums.com/forums/f542...ml#post2056067
I first discovered their presence when I winterized and swapped out the filter for the shunt...not realizing the gasket had still with the filter instead of remaining in the female end of the hose.
I have a few in my Parts bag along with fuses et, al.
CruizinDux is online now   Reply With Quote
Old 01-17-2018, 11:01 AM   #10
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Frankct,
We're sorry to learn about the water pump issue you described in your 22' 2017 Sport. Please call our customer service and technical support team at*1 (877) 596-6111, option 2 so we can learn more and help.
Thanks.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is online now   Reply With Quote
Old 01-20-2018, 05:21 PM   #11
I want to thank everyone for your help. My problem was air being sucked in at the water inlet.
Old 01-22-2018, 10:31 AM   #12
urnmor's Avatar
Berlin , Maryland
Glad to hear that you got it fixed.
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 02:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 02:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 03:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 11:11 AM
