Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 04-17-2003, 11:04 AM   #1
Mr. Bliss
Mr. Bliss's Avatar
Profile:
Water pump pressure duration?
On my newly acquired '57 the water pump (powered by DC) seems to take foreeeeeever to pressurize. Three minutes or so to generate only 2 lbs of pressure.
Is this normal?
Dave
Mr. Bliss is offline   Reply With Quote
Old 04-17-2003, 11:12 AM   #2
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
No Dave, that is not normal.
If all the air has been purged, your pump is good and no leaks, suction or discharge lines, it should take less than five seconds for it to satisfy and shut off.
Chas
Chas is offline   Reply With Quote
Old 04-17-2003, 11:15 AM   #3
dmreilly10000
dmreilly10000's Avatar
Profile:  1953 25' Cruiser
Brandon (near reservoir) , Mississippi
Images: 14
Does it have a pressurized system that doesn't use a pump, but a small compressor to "force" the water out of the faucets? Or is it a more modern type pump?
In my 1963 Overlander (now sold), it had a compressor. I don't know what originally came in my 1953 Cruiser, but it looks like it also had a pressurized system.
We need to know this to determine a solution to your problem.
dmreilly10000 is offline   Reply With Quote
Old 04-17-2003, 11:40 AM   #4
Mr. Bliss
Mr. Bliss's Avatar
Profile:
It has a 25 gallon horizontal holding tank, with a small compressor (which says to monitor oil...but probably has never been done, and I'm not sure where to fill it).
No other obvious leaks. Does this help?
Dave
Old 04-17-2003, 11:47 AM   #5
dmreilly10000
Images: 14
Dave
Yes it does help. Your compressor is probably shot. Mine was. I would convert the system to a modern pump instead of fooling with the compressor.
Old 04-17-2003, 03:44 PM   #6
Mr. Bliss
Mr. Bliss's Avatar
Profile:
I was thinking this was the case. Any suggestions to make and mfr? Any notion for cost for such systems?
Dave
Old 04-17-2003, 03:55 PM   #7
dmreilly10000
Images: 14
Here is a link for Camping World mail order:
http://www.campingworld.com/browse/c...D=137&subOf=13
The hard part (maybe not) is plumbing it in. You will also have to loosen or remove the filler pipe cap on the outside of the trailer so that air can vent into the system, (otherwise the pump will create a vacuum) or otherwise vent the tank.
Old 04-19-2003, 09:57 AM   #8
trailertrash
Profile:
Buy a Jabsco- I never buy anything from a camping store- they have the lowest quality and cheapest parts around. Try and crossover what your looking for with something from the yacht and marine industry. You'll pay a little more, but the results are well worth it.
I was in a delux camping store in Phoenix 2 days ago, and looked at their selection of pumps. All ShurFlo junk.
The average camper doesn't know the difference, and thats why companies like Terry have stayed in business and prospered. We own a better product, and should support it as such...
Try www.lewismarine.com
trailertrash is offline   Reply With Quote
Old 04-19-2003, 11:08 AM   #9
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
trailertrash,
I love that moniker, by the way....
I agree on the rv store junk. Camping world has a huge collection of Asian imported junk on their shelves. Of course there are a few quality US made items as well, but the majority is really cheesy.
I purchased some brass water fittings and lamps there before, none of which are with me any longer. The 3-way faucet adaptor I bought there flew apart after just a few minutes of service, and the water inline pressure regulator's treads are poorly cut, resulting in having to use pliers to put it on a faucet. You will find many of the same items in marine stores, but I do think that overall the marine item quaity is indeed better. Partially because boats have tighter liability clauses and have stricter safety regulations.
Uwe
Old 04-19-2003, 01:10 PM   #10
trailertrash
Profile:
... I don't even buy the stuff that West Marine sells, unless I look it over VERY thoroughly, or know the brand and recognize the product as a quality one...
The "chain" concept has somewhat cheapened the boat market as well, so beware...
All it takes is for some of you guys to realize the difference, and you'll be buying from Lewis Marine for as many of your projects as possible.
The good thing about them is that they screen their products and reject any BS that may cause problems- for us and them.
I'm really fortunate- they're close enough that I can drive there- but check out their online catalog, and if you like what you see, call them and order their 1000 page printed one...
Old 04-21-2003, 12:02 PM   #11
Mr. Bliss
Mr. Bliss's Avatar
Profile:
Lewis Marine
Trailertrash....
How does one do business with these folks? Initial attempts via phone and web have not been too stellar.
The web address for sales@lewismarine.com does not exist. On the phone I was told that they do not do business with the public, only marinas, then was referred to a NY location, who told me the same. After some pleading, they gave me a local marina number.
Dave
Old 04-21-2003, 11:31 PM   #12
trailertrash
Profile:
Call them and tell them that you want to open a "50" account- its their level slightly above wholesale and they should sell you a catalog for about $10 plus shipping, and then set you up. They also have a retail store in Stuart Fl, so they aren't totally wholesale...
Water Pump David Hall Water Heaters, Filters & Pumps 8 01-12-2004 09:31 PM
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 01:12 PM
water pump pressure AccessMaster Water Heaters, Filters & Pumps 3 08-22-2003 10:38 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 08:12 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 11:35 AM
