pump action...
Hi!
You will have reasonably good pressure when you first open the faucet after the pump has stopped. It will drop off as the pressure drops and the pump kicks back in. After that, you'll get the volume of water that the pump is capable of moving. The volume isn't going to be great, and not under a lot of pressure, but it should be adequate.
If the volume is really low, it may be time to replace your pump.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
