Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 12-19-2005, 06:08 PM   #1
PhilMateo
Profile:  1965 26' Overlander
Acworth , Georgia
Water Pump Pressure
What water pressure should I see on replacement water pump when running off power hookup and using fresh water tank?
My newly purchased 65 Overlander has a new water pump installed by PO last week.
PhilMateo is offline   Reply With Quote
Old 12-19-2005, 07:37 PM   #2
Buttercup
VAC Membership Chair
Buttercup's Avatar
Profile:  1977 27' Overlander
1954 25' Cruiser
VC Highlands , Nevada
I would expect 20-40 psi would be enough. Not higher than 60!
Don't let the IBT Scuttle the WBCCI - Just Vote NO! Save Wally! Buttercup Web site Looking for a unit? Check out the SaveWally Unit Guide.
WBCCI # 17330, VAC Membership Chair, CAC Member
2008 Mouse count:
Buttercup -
Airtini -
Buttercup is offline   Reply With Quote
Old 12-20-2005, 08:16 AM   #3
PhilMateo
Acworth , Georgia
Thanks...that will work then.
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 07:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 10:13 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 08:12 AM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 04:02 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 11:35 AM
