Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 10-12-2005, 09:17 PM   #1
ssolid
SSOLID
Profile:  1972 25' Tradewind
Merritt Island , Florida
Water Pump Pressure???
Should the water pump pressurize the whole system including the water heater?
If so, is it recommended to use the water heater while using the water pump? I don't want a molten pile of Airstream!
Steve
ssolid is offline   Reply With Quote
Old 10-12-2005, 09:24 PM   #2
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Yes, it should. As long as the water heater is full of water, it will not melt down. If you run your fresh water tank down to zero, you will still have a full water heater tank, unless you drain it through the drain valve in the heater tank itself.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-12-2005, 09:55 PM   #3
ssolid
SSOLID
Thank You
Thank you for the quick response...we are heading to the Smokies and of course I have some last minute questions. I appreciate all the shared knowledge on these forums and look forward to the day when I can be helping instead of asking.
Steve
Old 10-13-2005, 12:59 AM   #4
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
If the heater's on, maintain pressure..
I think question reversed.. I f you're going to use the water heater, then you should either be connected to "city water" with a hose and valve opened, or the pump should be on to maintain pressure from the tank. If you're not confident in pump, and leaving the trailer, turn off the water heater when you're away...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 07:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 10:13 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 08:12 AM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 04:02 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 11:35 AM
