water pump not working
Greetings Sbcoyle!
Welcome to the Forums and the world of Vintage Argosy ownership!
If your Argosy 24's wiring is similar to my '78 Minuet, you may find that you have a blown fuse as the water pump and range exhuast vent fan are on the same circuit. You may also find a pinched wire in the vicinityof the exhaust vent fan as this was the culprit of periodic blown fuses in my Minuet just after purchase.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
1978 Argosy Minuet 6.0 Metre
