Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 05-06-2008, 03:23 PM   #1
Profile:  1976 Argosy 24
Joplin , Missouri
Water pump not pumping
Hi this is Sandy's(Isadora) husband Jim. She's trying to teach me how to use this forum! |
I have a problem with the water pump on our 76 Argosy. Pump runs but does not pump water. Its a Parr pump. Is there a trick to get to pump water?
Isadora is online now   Reply With Quote
Old 05-06-2008, 04:34 PM   #2
Profile:  2007 20' Safari SE
Madison , South Dakota
Don't know if this will work for you or not but I had this problem twice with another brand of trailer - not sure what brand of pump it had. Both times I partially filled the water tank and then went out and drove around for a few minutes and when I finished the pump worked fine. Maybe the water sloshing around "primed" the pump and cured the problem. Worth a try if you can't come up with anything else.
Al - K4GLU is offline   Reply With Quote
Old 05-06-2008, 04:56 PM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 36
I have a valve between my pump and the tank. It is used to winterize the system. It could cause the same problem.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 05-06-2008, 06:14 PM   #4
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Smile Hi
Fill your water tank to the top this will push water into the lines and help with the priming. Also hook up city water and presurized your lines. Aftret you presurized thelines turn of the city water and try the pump again. It works for me.
Regards from Russell
RUSSELL is offline   Reply With Quote
Old 05-06-2008, 06:17 PM   #5
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
I have a 3 way valve on the suction of the pump to draw anti-freeze. I left it open and it just sucked air vice pumping water. Pressurizing the system with city water is an excellent sugestion. I would think it was a priming issue before a faulty pump. Those pumps seem to last forever.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 05-06-2008, 07:49 PM   #6
Joplin , Missouri
Thanks will fill the tank all the way up, I only filled it halfway. And I had drained the lines after having the city water hooked up to test the pump to see where it leaked (and tightened the screws where it was leaking) so tomorrow I will pressurize those lines again and see it that helps.There is no three way valve on there (yet) so that isn't it.
Pingbacks are On
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
fresh water tank level and pumping Lumatic Fresh Water Systems 8 12-24-2007 05:51 PM
68 water pump-should the pump cycle? Gen Disarray Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Pumping out an Airstream honeywagon Waste Systems, Tanks & Totes 3 08-05-2006 08:08 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
