Old 07-01-2009, 07:17 AM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Water pump ??? Noisey or quiet ??
On another thread I addressed a problem with the water system in my '85 Excella. Once diagnosed it was a easy fix. Now with the fresh water system working nicely I have a question regarding the noise to be expected from the shurflo water pump. It runs on demand but seems to make a lot of noise. Before the fix the system was sucking air and forced water through the faucets in spurts. But with that problem the pump seemed to make much less noise. Now that the air problem is resolved the noise seems to be more noticable. The system seems to be working as expected dispite the noise from the pump so it just may be something I will have to learn to live with.
Thanks to all for your inputs into the forums.
Roger, from NJ but in Kansas now.
polarlyse is offline   Reply With Quote
Old 07-01-2009, 07:27 AM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
We installed the shureflow pump silencer kit from Camping World and I added new rubber base I made to our system and it is really reduced the noise.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 07-01-2009, 07:28 AM   #3
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Roger,
The pumps in both our '87 and '06 are fairly noisy. We just live with it. Once they need replacing I may look into a model that is quieter.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-01-2009, 07:30 AM   #4
DEITZ645's Avatar
rickandsandi,
Thanks for the informaiton, I didn't even know there was such a beast. I'll have to order two tonight. I just hope there's room to add the extra fittings and hoses.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-01-2009, 08:26 AM   #5
2005 22' Safari
1960 24' Tradewind
Originally Posted by DEITZ645 View Post
rickandsandi,
There should be enough room for them. The thing to remember is to set it up so that the lines are not touching anything, that is were most of the noise comes from. Let use know how it works out.
Rick
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 07-01-2009, 08:38 AM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Mounting the pump on some rubber washers should isolate it to some extent from the body and may help with noise. I've been thinking of doing that for a year or so, but by now we have gotten used to it. It helps to remember to turn it off when not using water since the pump from time to time goes off when some air bubbles work their way through the system.
Gene
Old 07-01-2009, 08:41 AM   #7
Mexray's Avatar
1978 28' Ambassador
Morada , California
Another issue with water pump noise is due to it's mounting - usually the plywood it's screwed to act's like a 'sounding board', amplifying the pumps sounds....
I reduced the sound to a large extent by mounting the new variable flow pump on it's own board that is then isolated from the floor board by some 2-ply foam sheeting the 'floats' between the two surfaces.
Some flexible hoses as show above completes the noise abatement project....
Ray & Pat; Morada, CA
Old 07-01-2009, 08:55 AM   #8
Master of Universe
Gene's Avatar
Mexray, an elegant solution. The screws used to secure the pump also transmit the sound to the plywood, and isolating them from the plywood is a great idea.
Gene
Old 07-01-2009, 06:34 PM   #9
retired USA/USAF
2001 30' Excella
Thanks for all the suggestions. I'll try and follow up and see which work the best.
Thanks all,
Roger
Old 07-01-2009, 09:35 PM   #10
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
My husband just installed the flex hose today and it made a big difference. He had to tie them up a bit because they were still touching things in the cabinet. He also wrapped it with pipe insulation.
I really like the ideas Mexray and Gene stated. Maybe that will be the next step. Thanks all!
Lisa
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
bolerama is offline   Reply With Quote
Old 08-12-2009, 12:43 PM   #11
2012 27' Flying Cloud
Denver , Colorado
We just brought our 2008 International 23D home to Colorado and I'm going to look into this sound abatement project. I assume this pump is under the bed? Or do I access it from outside the trailer via an opening panel?
JimmyT is offline   Reply With Quote
Old 08-13-2009, 05:14 PM   #12
Master of Universe
Gene's Avatar
The pumps are in different places in different trailers. In ours, there's a panel under the refrigerator with a heat register in it. It does not have a handle. You have to kind of pry it with your fingers on the right side and open it stretching the flexible duct. The pump is installed in a maze of tubing and in a way that it is nearly impossible to get to the filter to clean it. The best thing to do is to re-plumb it while moving it closer to the door, reversing the direction to have the filter in front, install a bypass so you can directly run antifreeze through it and the lines in the trailer without putting antifreeze in the fresh water tank. Bypass kits for water pumps are available from RV stores. Mount it on rubber and then you've done all the things Airstream should have done.
If it's under the bed, you're lucky.
Gene
Old 08-13-2009, 05:24 PM   #13
bolerama's Avatar
Images: 30
Hi Jimmy, on the 23D it is under the closet beside the bathroom sink. As Gene said, it is behind the access door that has the furnace vent. It just looks like a panel, but it is a door. Pull it hard.
By the way, there are 2 small cupboards under the other closet and pull-out pantry. There are no handles on these. Pull them hard to get them open. The person who sold it to you may not have shown them to you.
Have fun!
Lisa
Lisa and Paul
Old 08-13-2009, 09:24 PM   #14
Denver , Colorado
Thanks, Lisa and Gene.
We found the "secret" cupboard under the closet at the foot of the bed - owner showed us that one. The one to its left, under the pantry, doesn't seem to want to open; doesn't seem to be any room back there anyway. I'll take a look at the water pump location next to the bathroom sink. Thanks for that.
Jim and Marsha
Old 08-13-2009, 10:35 PM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Jim and Marsha
Hi, some of these secret panels just pop off and some have a hinge on one side, so if you pull on the hinged side you won't get it to open. Hope this helps.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Want a new water pump, looking for quiet ronstory Water Heaters, Filters & Pumps 2 08-04-2008 10:22 AM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
Flo-Jet quiet pump control?? myoung Water Heaters, Filters & Pumps 10 12-15-2006 05:40 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
