Old 09-19-2015, 04:34 PM   #1
Tincampers's Avatar
Sneedville , Tennessee
Water pump noise almost completely gone...
After trying a number of non-solutions, I bought some of the really small shock cords and some eyelet type screws. I removed all the screws from the pump and the clamps and then install an eyelet front and back of the pump as close to the wall as possible. I then used a larkshead to attach the shock cord to each eyelet and then put the shock cord hooks through the screw holes on the pump base. I then used 2 more shock cords to pull the pump down a bit so that it touches nothing. It is so much quieter now. I hate that thing. I'll try to get some pictures.
Tincampers is offline   Reply With Quote
Old 09-19-2015, 05:11 PM   #2
Tincampers's Avatar
I'm on the iPad and am having issues posting pics. Here are some.
https://picasaweb.google.com/1054506...eat=directlink
Old 09-19-2015, 06:06 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Originally Posted by mrprez View Post
I hate that thing.
Sounds like some of my projects.
Looks like a good solution, too!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 09-19-2015, 06:16 PM   #4
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
Same concept as used on high-end condenser microphones to isolate sources of vibration that carry through to recordings...except in your case you're eliminating the pump's vibrations from being amplified by the walls of your AS. Good thinking!
Nomad518 is offline   Reply With Quote
Old 09-19-2015, 07:01 PM   #5
Tincampers's Avatar
Yep, it seemed like it was shaking the entire closet it is mounted under. I tried to post a video but it wouldn't work.
Old 09-19-2015, 08:03 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
Mine is on carpet. I hardly hear anything but a slight hum.
CRH is offline   Reply With Quote
Old 09-19-2015, 08:17 PM   #7
Tincampers's Avatar
Carpet! D'oh! Good idea.
Old 09-19-2015, 09:36 PM   #8
2014 31' Classic
Southwest Michigan , Michigan
Excellent NVH work. Isolation is the best defense against noise.
ratchet is offline   Reply With Quote
Old 09-20-2015, 10:19 AM   #9
gecko's Avatar
2009 28' International
Pacific Palisades , California
We used scrap decking material from windsurf boards--comes with sticky back so easy to apply, and it's waterproof in case of a leak in water carrying areas. Found that sometimes it's the connecting water tubes that are vibrating, rather than the pump itself.
gecko is offline   Reply With Quote
Old 09-20-2015, 10:39 AM   #10
olympia , Washington
to me, it is sad that for so much money on a unit like an AS, the owner has to do something that the manufacturer should improve/fix.
Xicaque is offline   Reply With Quote
Old 09-20-2015, 10:51 AM   #11
1979 28' Airstream Excella 28
Oakwood , Georgia
water pump
Glad for you fix. ( 1979 Excell motorhome) I had a slight noise pump, but also had two pumps to freeze and burst. I kept heat in the camper but the pump was freezing thru the foor from the outside. I put a 1" block of styrofoam and remounted. Now quite and no freezing thru the floor.
brockgarrett is offline   Reply With Quote
Old 09-20-2015, 11:23 AM   #12
shadedsilver
2014 27' FB International
Bisbee , Arizona
Sounds like a year solution. Picture would be appreciated.
shadedsilver is offline   Reply With Quote
Old 09-20-2015, 11:23 AM   #13
shadedsilver
Bisbee , Arizona
Sounds like a great solution. Picture would be appreciated.
Old 09-20-2015, 04:58 PM   #14
Flying Cloud 27
smlbob's Avatar
2015 27' Flying Cloud
Union Hall , Virginia
After one night of no water hookup, the wife decided I would do something to quiet down that silly onboard water pump. Thanks for the suggestions ! As soon as I get home from this trip.
smlbob is offline   Reply With Quote
The Snow is ALMOST gone! Time to get busy.... gmaof20 Vintage Kin 14 07-28-2013 04:13 PM
My beautiful Airstream is gone, gone, gone. mhilley On The Road... 55 02-12-2012 10:44 AM
That page peal is gone! IT's GONE! GONE! YES!! AIR-Quarius Off Topic Forum 2 10-11-2010 02:18 PM
almost....almost.... rama777 Electrical - Systems, Generators, Batteries & Solar 30 11-04-2006 10:18 AM
