Originally Posted by wheel interested
blah blah blah
....And while I am at it, may I ask should there be a length of small diameter heat ducting that just ends with a raw edge in the space there by the water pump with no tie down or particular place to go?
Hi Carol
I just read this and, FYI, my small diameter heat duct is actually pushed down a
"hole" to blow directly on the tank walls. It is not just laying beside the pump.
Your model may be different.
I was browsing this thread because my pump seemed to be getting louder and
louder. Finally a week ago, while camping, I was sitting outside and noticed
water running down the side of my AS. I was hooked up to water, and it was
coming out of the spot where you fill the water tank. I assumed the pump's
check valve was shot, so i installed a SHURflo Extreme™ Smart Sensor™ 4.0.
I may have been able to just replace the check valve, but I was tired of all
the noise. The SHURflo is much quieter.
There are some really good tips in this thread, thanks.
