Old 10-18-2012, 06:22 AM   #1
Gainesville , Florida
Water pump location
I know the water pump is under the floor in the closet next to the shower in a 2005 safari 25 ft FB, but how does one gain access to it? I cannot get the floor bottom to pull up, is there another way? Jim
Old 10-18-2012, 08:10 AM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
On my 2006 FB there is a panel below the closet door that is hinged and secured with a cabinet catch. Just stick a screwdriver behind it and pop it open.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is online now   Reply With Quote
Old 10-18-2012, 10:29 AM   #3
thanks, I will try that, jim
Old 10-18-2012, 12:54 PM   #4
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
Is the refrigerator next to the closet? If so, open the small storage door under the refer. The back panel is held in by 2 screws. remove the screws and pull the panel out. The pump is right there. At least it is on the FC...
Good Luck
drew05 is offline   Reply With Quote
Old 10-18-2012, 01:10 PM   #5
I will try that also when I get a chance. Thanks, jim
Old 10-18-2012, 02:15 PM   #6
Panel under refrig was a no go, but I noticed the panel under the closet with the heater vent was loose so I pulled on it and it hinged open. Voila, there is the water pump with duct work above it. I found a piece of clear tubing about a half inch in diameter loose at one end. Can not tell where it is connected. It would be easier if the floor of the closet hinged up and then clear access to everything would be available. Any ideas on the tube! I may ake a saw to the closet floor to gainbetter acces. Jim
Old 10-18-2012, 03:40 PM   #7
Lost in America
mojo's Avatar
Oak Creek , Arizona
Did you buy your trailer used? If so, someone may have installed a 3 way valve on the input side of the pump and the clear hose would then slide into a jug of RV antifreeze for winterizing when you turn the valve. It's not a Florida thing....
2017
Old 10-19-2012, 06:15 AM   #8
Thanks, I will look into that, jim
