Old 09-21-2011, 06:34 PM   #1
2011 25' FB International
Toronto , Ontario
Water pump Issue.
Hi everyone,
We recently upgraded our 23' Safari SE to a 25' International Serenity Edition. We took it on a maiden voyage the other weekend, and one or two issues came up. Yes, they are covered under warranty, but my dealership is a 3.5 hour round trip from home.
I'm hoping someone can offer me some advice regarding the water pump. It's simply not working at all. Yes, I know where the "on" switch is on the sensor panel. I've also checked the fuse box and the in line fuse on the power line that feeds directly to the pump.
When I switch the pump on, nothing happens. The water tank is full. On my previous AS, I'd always hear the pump run for a second or two when I switched it on. With the new one, it doesn't make a sound and pumps no water when I open a tap.
Other than the fuses, which I checked already, could there be something simple that I overlooked? Or something that the dealership overlooked? Is there a by pass valve for the pump that may have been left open when the dealership was prepping it for us?
Any help would be appreciated. We're planning a two week trip to Fort Wilderness in October, and I'm not sure I'll be able to fit in a trip to the dealership prior to then. The water pump is the only issue with the AS that I can't just live with until after our vacation.
Cheers.
Toronto_Guy is offline   Reply With Quote
Old 09-21-2011, 06:54 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
TG
deja vu all over again...
Ours failed the second time it was turned on....first camping trip.
Spent half the first day with the WP on the picnic table fixing a separated wire where it enters the pump body. Had to cut back the insulation right at the pump
to expose enough wire to make a splice. Got lucky. But not a happy camper.
Don't know if yours is the same brand, but it's worth a look-see.
You might try several solid taps on the housing while flipping on/off.
Good Luck...eah
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 09-22-2011, 05:36 PM   #3
Toronto , Ontario
Thanks! I'll check the wire the next time I drive out to my AS. I'd rather spend a few hours fixing it before my vacation than during my vacation. ;-)
Originally Posted by ROBERT CROSS View Post
TG
Good Luck...eah
Old 09-22-2011, 06:36 PM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Do you have a basic voltmeter or a 12v test light? Check for 12v at the pump with the switch on. It could be as simple as a disconnected wire.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 09-22-2011, 08:22 PM   #5
Ottawa , ON
Why not at least call Can-Am? Ask for Andy Thomson (the Boss), and see what he can suggest.
If all else fails, it really isn't that far to London, is it? I mean, not to a rootin'-tootin' Airstreamer?
Old 09-23-2011, 04:46 AM   #6
Lily&Me's Avatar
Normal , Illinois
Might also call the service department where you bought it, they may be able to help you over the phone.
We didn't have the luxury of hookups at the dealer, figured a lot of things out on the road and sometimes with Eric-the-service-guy on the cell phone.
Maggie
Lily&Me is online now   Reply With Quote
Old 09-23-2011, 06:45 AM   #7
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
If you have checked that you are getting 12vdc at the pump, and if there is not a problem with the motor itself - which could be the case, I wonder if there might be a problem with the pressure switch (I assume it is built into the pump).
If the switch is not closing when pressure in the system isn't up to the required level, the motor won't see 12v and won't run.
Just a thought.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Interstate coach water pump problems solar-guy Sprinter and B-van Forum 10 06-03-2015 02:51 PM
Water pump running with no water! Michigander Fresh Water Systems 11 07-25-2011 03:04 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
