Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 12-03-2004, 01:21 AM   #1
TroutStream
TroutStream's Avatar
Profile:
Water Pump - Fuse Amperage???
While winterizing I discovered a blown fuse to water pump. The old fuse looked to be 6.4 amps. I blew a 7.5 amp fuse within 15 seconds and as I needed to drain fresh tanks and circulate the antifreeze I tried a 10 amp fuse. The fuse worked fine.
Am I risking damage by running 10 amp fuse??? and does anyone know what the original would be for 1970???
Thanks to all.
Ken.
TroutStream is offline   Reply With Quote
Old 12-03-2004, 07:50 AM   #2
RichardT
RichardT's Avatar
Profile:
If my memory is correct, then you will want to use a 6 1/4 amp SLO-BLO fuse, If there is a short and you use a 10 amp fuse you run the risk of overheating and damaging the wiring going to the water pump.
RichardT is offline   Reply With Quote
Water Pump cycles often Guitars Water Heaters, Filters & Pumps 3 11-19-2002 08:04 PM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 07:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 10:13 PM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 04:02 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 11:35 AM
