Old 09-29-2015, 10:05 AM   #15
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
Originally Posted by SCOTTinNJ View Post
In my case I was thinking of the accumulator so the pump wouldn't kick on every time I cracked a faucet. Thinking it would stop some of the cycling, including the problem the OP is having.
Yes, we're talking about the same thing. Same answer from me.
I would note that all the ShurFlo constant pressure pumps that I have seen have a recommendation from the manufacturer that they be switched off when not in use. Are the newest ones different? Does anyone have the instruction/installation sheet from a recent model?
1989 345LE
Punch is offline   Reply With Quote
Old 09-29-2015, 10:53 AM   #16
ericpeltier's Avatar
Superior , Colorado
The intermittent cycling is not normal or OK. My system does not do this at all. I'd go leak hunting.
I installed an accumulator and love it. It means the pump does not turn on so quickly, and the noise of the pump and water hammer effect is greatly reduced. Just my $0.02. In my next trailer, I might install 2 accumulators. If one is good, two is better, yes?
ERic
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 09-29-2015, 10:57 AM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Our City Water check valve was allowing a 'weep' of water... replacing stopped the 'running' of the pump...
BTW, we have a built in 'accumulator' under the kitchen sink.. stock.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-29-2015, 11:05 AM   #18
dznf0g's Avatar
Oswego , Illinois
ERic
In my old SOB I installed a 1 gallon accumulator under the couch. That was sweet!
-Rich-
Old 09-29-2015, 04:29 PM   #19
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Like Rich above, I have installed a SHURFLOW accumulator in my '15 Classic. It's in-line with the water pump and works very well. I'd done this with my 28' Intl CCD and found it virtually eliminated the cycling issue. Would be nice if Airstream did this as part of the standard plumbing setup, but that's one more economy.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 09-29-2015, 06:07 PM   #20
Rivet Loser
Punch's Avatar
I installed a ShurFlo constant pressure pump. Airstream had already put an accumulator in my MH in 1989 because the old pump was not constant pressure. The new pump was great, and I was quite happy to let the accumulator sit there and do nothing, because it is simply not necessary with a constant pressure pump.
I don't know if that pump clicks for half a second, one second or 3 seconds every hour, two hours or three hours, or if it never clicks at all. I don't listen for it and I couldn't care less whether it does. If I heard it clicking regularly I would take notice.
Life is too short and complicated already without spending time adding unnecessary complexity.
1989 345LE
Old 09-29-2015, 07:09 PM   #21
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Images: 135
Great information, thanks all for your help.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 09-29-2015, 07:11 PM   #22
2007 22' International CCD
My 2007 factory pump does not cycle at all overnight as long as the faucets are shut properly.
KE4GNK/AE
Old 09-29-2015, 07:27 PM   #23
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
If no water is being used or needed.....why is the pump on?
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-29-2015, 07:42 PM   #24
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
A drip from the hot water tank pressure relief valve will also cause the pump to cycle briefly.
2012 Dodge Durango Hemi/AWD
Old 09-29-2015, 10:44 PM   #25
1974 Argosy 20
Kooskia , Idaho
I have a well and pump in my home. I certainly don't shut it off when no water is being used or needed. Same in my Airstream and Argosy. The pump stays on unless I run out of water. I usually forget to shut it off between trips too. It just sits there waiting for me to come back.
Living dangerously I know....grin. But I like water to flow when I turn on a faucet, or flush the toilet. Why have to turn the pump on and off? That is what pressure switches are for.
Random Water Pump Cycling Hummingbird Fresh Water Systems 11 03-05-2014 11:44 AM
Dometic Heat Pump Cycling BAB Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-25-2013 08:20 PM
Cycling Water pump with no water leaks TheProfessor Water Heaters, Filters & Pumps 4 03-30-2010 06:54 PM
Water pump cycling every 1-2 sec?? BOBHASTINGS Water Heaters, Filters & Pumps 19 09-06-2006 04:22 PM
Water Heater Cycling? BigAl Water Heaters, Filters & Pumps 0 07-06-2004 08:48 PM
