We have a 2011 31 foot Classic. The Water pump has been cutting out regularly when we detach our waterline due to freezing temps. It'll work one time and then a minute later it won't. I've checked the circuit breakers, they're ok. Is there anything else I can check before taking it in for warranty work?
More details are needed. Under normal circumstances the pump should cycle on and off depending on demand.
When you open a faucet. Does the water start and stop or run with a variance in pressure? Which is normal.
I'm not familiar with the newer AS, but I wouldn't think you should have your pump turned on if you are on city water.
If you are not on city water, you need to have water in the fresh water holding tank.
Of course there is water in the tank. You can run the faucet, water comes out fine. shut it off. come back a minute later and there is nothing, no pump noise, no trickle of water--dead. Toggle the pump off and on, nothing.
come five minutes later and it runs. There is probably a loose connection somewhere in the system...trying to trace it down is the problem. I found some info in related posts..
Check the wire connectors at the pump. I had this same problem awhile back and found one of the crimped connectors was broken on one wire. I replaced the connector and it worked fine from then on.....
__________________ History doesn't repeat itself, people do!
