Old 09-13-2011, 06:17 PM   #1
1977 31' Sovereign
Maricopa , Arizona
Question Water pump
Restoring a 1977 airstream 31ft. The water pump was missing so we put in a new one. Just filled the water tank and nothing happened. Do we need a fuse somewhere? Does it need to be primed? Any help will be great.
DonReg is offline   Reply With Quote
Old 09-13-2011, 06:33 PM   #2
kipper's Avatar
2006 19' International CCD
Hatboro , Pennsylvania
HI , the pump does not need to be primed , do you have power at the pump , do you have the switch for the pump on ? Good luck
Kipper
If everyone is thinking alike, then somebody isn't thinking.
George S. Patton
kipper is offline   Reply With Quote
Old 09-28-2011, 10:06 AM   #3
1976 31' Sovereign
Marlette , Michigan
like Kipper just posted, the pump needs no priming and you do need power!!! my question would be. could there be a broken water line some where? that would effect the vacume that's needed to have the pump draw water from your fresh water tank. also you need to purge the air from your system. good luck. also you could try hooking up to your house water supply with a garden hose to find any leaks. I just rebuilt my water supply because of frozen pipes and broken pump.
rymndmr is offline   Reply With Quote
Interstate coach water pump problems solar-guy Sprinter and B-van Forum 10 06-03-2015 02:51 PM
Water pump running with no water! Michigander Fresh Water Systems 11 07-25-2011 03:04 PM
No water from pump Castaway Fresh Water Systems 10 04-13-2011 08:59 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
