Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 05-05-2007, 11:18 AM   #1
moman
moman
Profile:  2004 25' Safari
stuart , Florida
Water pump
The Sureflow water pump on my 04 Safari keeps running. Its not cycling on & off, but just continues to run. At first I thought it was filling the hot water heater, but I looked at the see-through part of the pump & its only half filled. Any help would be welcomed.
eddie
moman is offline   Reply With Quote
Old 05-05-2007, 12:43 PM   #2
Killo1
Killo1's Avatar
Profile:  2005 22' Safari
Santa Ana , California
eddie
Sounds like what happened to me when I ran out of water. Try checking your water level.
Alan
2005 22ft Safari
2003 Chevrolet Suburban Z71 5.3l
"Life is like a box of chocolates..." Forrest Gump
Killo1 is offline   Reply With Quote
Old 05-05-2007, 12:56 PM   #3
Relentless
Profile:  2007 25' Safari FB SE
Blaine , Washington
Have you checked for leaks in the system? Start by looking in the toilet bowl.
John
"However beautiful the strategy, you should occasionally look at the results."
Winston Churchill.
Relentless is offline   Reply With Quote
Old 05-05-2007, 01:43 PM   #4
Tim A.
Profile:  2002 19' Bambi
Lafayette , California
The other suggested reasons for the water pump to keep running are good ones. There are a couple more. Air in the system is one. Another is if the pump, due to some mechanical problem, is unable to bring the water pressure up to its automatic shutoff level. The latter can be checked by turning the pump off and then hooking up to external, well-pressured water so that the RV's water system is at a pressure higher than the pump's shutoff pressure. Then turn off the external water and turn the pump on. If it does not start running again, open a tap until the pump does run, turn off the tap, and see if the pump continues to run on. If so, the pump could well be faulty. Obviously, we have had this experience!
Tim A. is offline   Reply With Quote
pump not working... Chuck Water Heaters, Filters & Pumps 23 05-16-2007 10:44 AM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 09:28 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 07:11 AM
Water Drip uwe Fresh Water Systems 6 07-11-2002 09:39 AM
Water filter system 53flyingcloud Our Community 2 07-05-2002 05:43 PM
