Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 04-17-2002, 01:20 AM   #1
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Question Water Pump
We have an original PAR water pump in our 1964 GlobeTrotter. The 4 rubber vibration isolators have obviously gotten hard & cracked after 38 years.
Does anyone know of a source for suitable replacements? We have searched at all the local sources we can think of to no avail.
Attached is a picture of the part we are looking for, any help would be greatly appreciated.
It measures approximately 1-5/8" x 3/4" each leg & 3/4" diameter. The top & bottom look the same. It is attached to the pump with one leg and to the trailer through the other.
Rob & Shari
InsideOut is online now   Reply With Quote
Old 06-04-2002, 09:29 PM   #2
Rick
Rick's Avatar
Profile:
Rob & Shari;
Chances are by now you will probably end up fabricating new isolators, which really is not that hard, and you can do it with regular hand tools. Go to your nearest auto parts store and see if they have generic rubber suspension blocks. They are usually hockey-puck shaped. Purchase two or three, and using your old isolators as templates, trace with a fine tip marker around the old isolator on the rubber block, and trim to size with either a razor knife (carefully!!) or a bandsaw. Then, drill out the appropriate holes. The isolators need not be perfect, so long as they fit.
Half the fun of renovation is invention!
Good luck!
Rick is offline   Reply With Quote
Old 06-04-2002, 10:51 PM   #3
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
I think they found them at West Marine. At least they said they did in this longer thread below.
http://www.airforums.com/forum...=&threadid=330
Now if they got them installed...How about it Rob or Shari, did they fit?
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 06-05-2002, 01:06 AM   #4
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
Yes Bobby et al, we got them installed. We think they worked fine....one will never know. We realized at the rally that the PAR pump had lost it's seal and would not maintain pressure...it would turn on & run, but not do it's job ~ pump water!
Oh well! After researching the options of rebuilding it, we realized a new Shurflo pump was a better alternative. The cost was just about a wash...Rob just installed it this last weekend, so now we are "good to go".
Shari
Old 06-05-2002, 08:28 AM   #5
83Excella
83Excella's Avatar
Profile:
Water pump
If needed, parts are available to rebuild/repair the ShurFlo pump. I carry an extra pump as a spare if the main one quits.
John
83Excella is offline   Reply With Quote
Water Pump David Hall Water Heaters, Filters & Pumps 8 01-12-2004 09:31 PM
Water Pump will not turn on AccessMaster Water Heaters, Filters & Pumps 2 12-07-2003 03:08 PM
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 01:12 PM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 10:13 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 11:35 AM
