Old 08-24-2019, 02:39 PM   #1
2018 30' Classic
New York , New York
Water pump
Does anyone else have problems with the lights dimming when the water pump cycles on? We have been having issues with the water pump. Had it replaced. The second gave out the next day and we got another. The original water pump dimmed the lights as well and eventually would only shut off if you shut it off at the switch.
Curious to know if I really have a water pump issue or a wiring issue?
ajwbarnard is offline   Reply With Quote
Old 08-24-2019, 02:46 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Sounds like you might have a grounding issue.
GMFL is online now   Reply With Quote
Old 08-24-2019, 06:06 PM   #3
2018 30' Classic
New York , New York
How so?
Old 08-24-2019, 06:17 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Just from the statement the lights would dim when pump came on would lead be to believe you might have a loose ground creating increase resistance.
Old 08-24-2019, 06:20 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Sounds like you have a couple of different issues.
1) When a water pump continues to keep running, it either means you have a leak, or the pump head is not able to maintain pressure, so it keeps running.
2) The coach lights will momentarily dim as the pump turns on, as it does draw quite a bit of energy. The only way to circumvent this would be to wire the pump directly to the coach batteries, instead of through the fuse block that the coach lights are hooked into as well.
Cheers
Sidekick Tony
Old 09-03-2019, 06:29 AM   #6
Reads a lot
Titusville , Florida
I’m just jumping in to say ....my lights will dim just a tad when the water pump kicks on while using battery power. It doesn’t happen when hooked up to 30 or 50 amp power source.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 09-03-2019, 06:53 AM   #7
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
On our 2017 25a AS FC when Vinnie’s recommend we upgrade to the new converter charger along with our new AGM 6v install to what AS now uses, a side benefit after the upgrade was the dimming lights stoped when using the water pump.
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 02:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 02:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 03:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 11:11 AM
