Old 10-21-2015, 08:30 PM   #1
Remax gal's Avatar
2014 27' FB Eddie Bauer
Lake Placid , Florida
Water Pump
We have a 2015 Classic and were packing it up to leave for a trip to the Smoky Mountains in the morning. I turned on the water pump and the water came out just like usual and then within 15-20 seconds, it slowed to a trickle. my husband finally located the pump behind the drawer under the refrigerator thinking maybe the filter needed cleaning. It was clean as can be. Any other suggestions? Also, if it needs to be replaced, do any of you know, will it require pulling the refrigerator out? I can't imagine how you can do any work in such a small opening. Thanks for your input!
Laura & Tom
Let the good times roll!! Laura
Remax gal is offline   Reply With Quote
Old 10-21-2015, 08:56 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Check for leaks. It sounds like it was sucking air.
CRH is offline   Reply With Quote
Old 10-21-2015, 08:56 PM   #3
SteveH's Avatar
Common Sense , Texas
Before you do anything with the pump, assuming it's still running, check the aireator in the faucet to insure it is not clogged with debris.
Regards,
Steve
Old 10-21-2015, 09:00 PM   #4
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
The short answer is no. The water pump is usually easily repaired or replaced as its a small motor with a couple hoses & electrical connection.
I got the feeling that maybe your fresh water tank may be very low or empty as some pumps won't function if there is no water to pump. Otherwise it's an electrical issue but most likely a bad pump.
Enjoy the Smoky's, bring a few gallons of bottle water to use between hookups & get it repaired when you get back to Fl.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
