Old 04-12-2015, 11:49 AM   #1
Water pump
What is the best pump
It going in my 68
New water tank, new heater ,new...
I want one with threads; not clamp fitting
Any help would be great
duckguts is offline   Reply With Quote
Old 04-13-2015, 02:48 PM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Shurflo is one major brand.
SHURFLO® REVOLUTION™ Pump 12 VDC 3.0 GPM | REVOLUTION™ 4008 Pumps
Old 04-14-2015, 01:04 PM   #3
I have seen some bad reviews on that one
Old 04-14-2015, 01:09 PM   #4
dznf0g's Avatar
Oswego , Illinois
I beleive that is the model I replaced my OEM Flowjet with. Has been flawless for almost 5 years. YMMV.
-Rich-
Old 04-14-2015, 02:20 PM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Sureflo is what I installed 5 years ago. PPL in Houston had the best price. I used Model 2088-422-444 and the the Sureflo inline strainer. I did have one minor leak at a hose connection which was my fault as I did not have the clamp tight. Clamp fittings are easy to install and easy to remove if needed, I don't have a problem with them. My pump is located under the front window on the street side where the original was. I added a relay at the pump (it draws 7 amps) so that the switch is only switching low current. Finally, for what it's worth, I have another Sureflo pump on a spray rig I built for my 4 wheeler. It is over 10 years old and it has been used countless hours each season spraying weeds on my farm. Never had a minutes trouble with it.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 04-15-2015, 12:40 PM   #6
I ordered a Seaflo needed the extra psi and flo rate for the tankless propane water heater
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
