Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Prev Previous Post   Next Post Next
Old 08-15-2009, 04:45 PM   #1
Profile:  1980 24' Caravelle
1980 24' Caravelle
1959 24' Tradewind
woking , surrey
water pressure problems
So, I decided to take some chances and took our 1980 caravelle out for a 2 week trip, 3 days after having picked it up from liverpool harbour..... Needless to say (especially as I am new to caravanning, let alone airstreams) that I had some system issues to resolve while on the road.
The one issue I have not been able to resolve is the fresh water system. The caravan supposedly has been used regularly and when I bought it the seller claimed all systems were working properly. Lets assume that that is true.
There is hardly any water coming out of the cold and hot water taps (from kitchen, shower or washbasin) and the pump keeps on running when I close all taps. I have tried taking out all air from the system per the manual (run pump with taps, cold and warm, opened marginally), checked for water leaks which I cannot find, closed the toilet water line, but no success.
The shurflow manual suggets that if the pump keeps on running air maybe trapped in the hot water tank (but that should have been sorted by letting the hot water taps open for a while) or air may be trapped in the pump.
How do you bleed the water pump of all air? Should the pump be able to do that by itself?
When I received the trailer, there actually was water in the watertank: pinkish, not smelling very nice (a bit chemical). I cleaned it with clorine solution, washed it with fresh, all with the pump via a t bracket just after the pump which has a 2 yard hose connected to it which can be led outside and can be shut off. That hose also did not have a lot of pressure with the pump on: It kind of overflows rather that water coming out with any kind of pressure. A thumb with light pressure can stop the flow (and the pump keeps on going, all taps being closed).
Any suggestions?
Thank you
Wiebe
turfclubroad is offline   Reply With Quote
Water Pressure tsunami Sinks, Showers & Toilets 2 04-30-2007 06:30 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
water pressure starflyte1 Fresh Water Systems 5 11-14-2006 01:07 PM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 05:45 PM
No water pressure gmlcjb Fresh Water Systems 9 12-29-2003 05:09 AM
