Old 06-07-2014, 12:52 PM   #1
2010 30' Flying Cloud
Garibaldi Highlands , British Columbia
Water, not so hot in shower
Hi, I was wondering if any of you have had that problem. I'ts only been a month now and the water in my shower is not as warm anymore as the water in my kitchen. First I tough it was my heater but the heater is fine and it's only like if the water in my shower would come warm but not as warm as it use to be.
Is there any adjustment I would have to do in my shower or something? I have been in Mexico for 5 months, the water is kind of salty there so I;m wondering if that could be the reason?
Thanks for help
Melimelo is offline   Reply With Quote
Old 06-07-2014, 01:36 PM   #2
SteveH's Avatar
Common Sense , Texas
We've experienced the problem also, and when it happened to us, I attributed it to lime and such coming loose from the inside of the water heater and partially plugging the small tapered inlet in the shower valve. It's a real pain to remove, disassemble, and clean the valve, if even practical, I don't know.
To check to see if this is possibly your problem, take the shower head off of the flex hose, and inspect the head inlet for trash. There may be some in there. Also check the kitchen and bathroom screens on the faucets for trash.
The only good news I have for you is ours eventually seemed to clear itself and we got hot water back.
Regards,
Steve
Old 06-07-2014, 01:58 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Most shower valves have limiters that prevent scalding water from being expelled from the shower head.
My bet is that it needs an adjustment.
My delta style faucet has an adjustment right under the handle.
(The handle must be removed by loosening the tiny allen head set screw)
Old 06-07-2014, 05:39 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
http://www.gilbertplumbing.com/episo...bpedia_001.php
Old 06-08-2014, 12:30 PM   #5
thank you guys for your reply I will definitely look and check it out closely, maybe it is just a bit dirty from the inside.
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 02:08 AM
To shower or not to shower? urbanfood Sinks, Showers & Toilets 55 07-20-2012 12:39 AM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 01:58 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 07:58 PM
