Old 09-16-2017, 10:28 AM   #81
2018 30' Classic
New York , New York
Originally Posted by GoinStreamin View Post
Sorry, photos posted twice.
I sent you a PM about figuring out pictures. We have found the hidden valve. We are trying to figure out if the picture is a before or after picture. This is what our hidden valve looks like now. We have not moved it yet.Click image for larger version
Trying to determine whether your picture is a before or after and if all the front valves should be in the position shown in pictures 1-3. Ours didn't, but they were positioned by the dealer technician when he was trying unsuccessfully to make it work.
ajwbarnard is offline   Reply With Quote
Old 09-16-2017, 12:21 PM   #82
2018 30' Classic
New York , New York
Does anyone know by looking at this picture if this valve is open or closed? There is a white pipe under the black tub that the black valve is attached to. The handle of the valve is pointing straight up. From the schematics of the AS manual
this appears to be valve #1
. And should be open in normal operation. Maybe if it closed and it should be open, this would prevent me from getting hot water. I did check the temps before and after on the Alde panel under the sink. The water and sanitary temperatures were in the 90's without the water heater being on. It went to 165 and 153 when the water heater was turned on. It appears to be making hot water, but never getting out to the faucet.
This is what the other three valves look like. I think 2-4 are in the right positions. I am not sure about what the yellow lever is or which direction it should be in but it basically only flips in a line from left to right.
It is frustrating that I am here on a Saturday and JC is not available on Saturdays. I do not live near my AS and cannot talk to them Monday-Friday from 9-5. I need someone to talk to when normal people aren't working.
Old 09-16-2017, 03:18 PM   #83
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by ajwbarnard View Post
Does anyone know by looking at this picture if this valve is open or closed? There is a white pipe under the black tub that the black valve is attached to. The handle of the valve is pointing straight up. From the schematics of the AS manualAttachment 295013 this appears to be valve #1Attachment 295014. And should be open in normal operation. Maybe if it closed and it should be open, this would prevent me from getting hot water. I did check the temps before and after on the Alde panel under the sink. The water and sanitary temperatures were in the 90's without the water heater being on. It went to 165 and 153 when the water heater was turned on. It appears to be making hot water, but never getting out to the faucet. Attachment 295015
Hi
Simple way to find out: Change the valve and see what happens.
Old 09-16-2017, 03:19 PM   #84
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Ajw, I'm looking at all the diagrams and pictures. The yellow lever is the safety valve, drains straight down out of the trailer, used when you have to "restore the air cushion in the domestic water heater chamber". If you download the 2017 Alde manual early in the Much Ado thread, read the part about monthly, or weekly during winter use, restoration of the air cushion.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-16-2017, 03:35 PM   #85
mojoe7009's Avatar
Green Cove Springs , Florida
Water/Hot Water 2018 Classic
It would seem the valve in the foreground in the middle of the white pipes is in the closed position. Normally the handle protrusion would be in line with the pipe to be open. Get the Alde manual and read it. The yellow valve is the drain for the hot water tank. Straight up is open.
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 09-16-2017, 03:49 PM   #86
Obviously-NOT
Kalispell , Montana
Ajw, your valve 1 in the picture above is shut off if the handle is perpendicular to the tubing. That looks like the cold water inlet to the water heater. I wish I could tell you which way to turn it to open, right (or left) to align the handle with the tubing, but in my trailer, I have some of each. But it needs to be open.
Red tubing is hot water out of the boiler, into the mixing valve and out to the trailer. The white tube into the bottom of the mixing valve from the safety valve is the cold mix water and loop over pressure protection.
Old 09-16-2017, 04:23 PM   #87
2018 30' Classic
New York , New York
Hi
If only it would move at all. But maybe trying turning it either way may result in it moving. We were trying left because of the instructions from another post. But try again, we will. Just didn't want to break it if it wasn't what we were thinking it was.
Old 09-16-2017, 04:32 PM   #88
Obviously-NOT
Kalispell , Montana
It's hard to gorilla torque those winky little valves with out a tool and break them. If you have exceeded your ability to change is position in either direction, cycle all the other similar valves in the area to determine if most of them are, "lefty loosee (open), righty tighty (shut). After your survey, try open in the same direction using a pair of pliars as gently as possible. Or take cold showers two more days till Monday, and let them break it.
Old 09-16-2017, 05:20 PM   #89
Obviously-NOT
Kalispell , Montana
Yes, valve #4 should be shut for normal ops. Anybody seen an Alde Manual for the 3020 units on the '18s? Yellow handle valve also normally shut, flat, unless draining the hot water boiler for air cushion.
Old 09-16-2017, 05:27 PM   #90
Obviously-NOT
Kalispell , Montana
Update...got wonderful technical support from customer service, this morning. After a couple of emails with pictures and a few turns of valves/knobs, we have hot water. Thanks to everyone for sharing their wisdom, from a set of Newbies. Now onto more discoveries! Happy trails everyone.
Ahoy, Stream mate, did AS share any secrets about the Alde Flow operation or a manual for your Alde 3020 system? The Classic Owners Manual still refers to the Alde Manual supplied at delivery. (Just like '17, but not provided).
Old 09-16-2017, 07:10 PM   #91
2018 30' Classic
New York , New York
After waiting for the Alde to be cool enough to work around the valve is now open and we are getting a somewhat consistent flow of warm water out. Now it may just need some tweaking of the mixing valve and maybe the anti-scald and we may actually be in business here.
Old 09-16-2017, 07:24 PM   #92
Reads a lot
Titusville , Florida
Ajw, good to hear. As I said earlier, none of this is difficult but it is a bit time consuming. I am not a very patient person so I wanted it to work immediately. It took lots of tweaking and a lot of waiting to see if anything worked. It appears you are heading in the right direction. Keeping going.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 09-16-2017, 07:33 PM   #93
2018 30' Classic
New York , New York
It appears that because our problem/symptoms were similar your fix that you posted seems to have worked for us as well. We would never have found that valve without your pictures. Thanks for taking the time to share what you had learned. It is appreciated.
Old 09-16-2017, 08:26 PM   #94
2018 30' Classic
Sanford , North Carolina
Originally Posted by james.mileur View Post
So, you repositioned one valve in picture 7? Or do all the other valves need to be repositioned to match the photos.
I found in '17 Classic plumbing, some quarter throw valves opened to the left, some to the right. They use both kinds. Did you shut the valve in picture 7, (handle perpendicular to the tubing) or open (handle in line with tubing)?
And does the system work using the water pump or only on shore water?
We only repositioned the one valve in pix 7 - hard turn left. The pix I provided was prior to the hard turn left. We did not try the system with the water pump, only shore water.
GoinStreamin is offline   Reply With Quote
Old 09-16-2017, 08:27 PM   #95
2018 30' Classic
So happy it worked for you! Happy trails!!
Old 09-17-2017, 07:43 AM   #96
Ponte Vedra , Florida
kendrick,
Thank you for the reply; we too can log approx 10-12 minutes of a shower with a very low discipline of navy showers. I was unsure if it was due to our location (FL) and relative temperature of the "cold" water" or fully functioning system. Last week when we evacuated from Irma we were in Knoxville area and presumably the incoming city water would be cooler than FL and still had very nice showers.
Paratus is offline   Reply With Quote
Old 09-17-2017, 12:17 PM   #97
Reads a lot
Paratus , so good to hear you had nice showers. You know, taking a nice hot shower isn't something we think too much about until ya can't. I know for a fact that JC had been telling Classic owners that 12 minutes shower was not possible, at least that was the case as recently as last month. Maybe the forum has allowed them the opportunity to change their mind about that. I know of at least 12 2017 Classic owners that are getting 10+ minutes of hot showers. Some got lucky and had the proper set up to start with from excellent dealers, some learned how to do it from here and another just kept tinkering until he got it (he wasn't a forum member).
Lauri
Old 09-17-2017, 01:31 PM   #98
Half a Rivet Short
Hi
I haven't run a stop watch on the shower process. We don't have a problem with the two of us running back to back showers. I've lived in apartments where that was an issue .... Once we got it to the "not a problem" stage we moved on to more important things (like how do you get a full case of beer in the fridge ...)
Water temperature out of the "shore" varies a bit. The same is true of the water temperature in your fresh water tank. You *could* be rumbling down the road with 34F water in the tank. Most well water will be in the 50 to 60 degree range. Water in a big tank in the sun is very much a "who knows" kind of thing depending on the season and sun exposure.
Old 09-17-2017, 08:50 PM   #99
2018 30' Classic
New York , New York
My husband took his first shower in the AS today with hot water. Shaved with water from the faucet and we did dishes without heating water on the stove. One flip of a valve and all seem to be working. Too bad it took 6 weeks to figure this out. That one valve is very well hidden. And we learned that the panel under the dinette seat comes off so you can see it at all. Now on to the next thing...
Old 09-18-2017, 05:27 AM   #100
Obviously-NOT
Kalispell , Montana
Hoo yah next thing. Congrats!
Towing 2018 33' Classic gbstats Towing, Tow Vehicles & Hitches 53 07-30-2017 05:56 AM
2018 Classic 30 and my experience Paratus 2016 - Current Classic (all lengths) 34 07-09-2017 09:58 AM
When to order a new Classic 30 (2017 or 2018) cetanorak 2016 - Current Classic (all lengths) 10 06-19-2017 08:56 PM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 02:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
