Old 03-02-2010, 01:08 PM   #1
frankfarmer's Avatar
1992 34' Limited
Snead , Alabama
Water Heaters, new tankless
Does any one have experience on these newer water heaters to replace the older tank models?????
frankfarmer is offline   Reply With Quote
Old 03-02-2010, 01:13 PM   #2
Kevin245's Avatar
Here is a recent thread. Post #2 has some links on the issue of tankless.
http://www.airforums.com/forums/f445...dea-61516.html
Good Luck,
Kevin
Eleanor Roosevelt
Old 03-02-2010, 01:19 PM   #3
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Rv 500
PrecisionTemp makes an RV approved tankless water heater, the RV 500. PrecisionTemp.com: For Recreational Vehicles and Boats
I installed one in my 1976 Sovereign in 2007 and have been very happy with it. It will fit in the same opening that your old water heater was in. Here are some pictures that I put together during this project.
Don
adonh is offline   Reply With Quote
Old 03-02-2010, 03:38 PM   #4
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
i replaced the not working water heater with the precision temp rv500 in our 61 bambi. had to make the opening a bit bigger since the old was 6 gal. i think the rv 500 requires the same opening as a 10 gal.
very pleased with it. it's quiet and works fast providing hot water.
folks at precision temp -at my request- special ordered their brushed aluminum cover without the brushed part-- i.e.raw aluminum cover which i think will polish up quite nicely and hopefully match the cherished alclad 2024t3 aluminum used in vintage airstreams. nothing better then a long hot shower/cold beer/outside while camping. esp along the outer banks.
i need to get an outside shower control for use on our 16footer.
rv500 does require a clean 12volt source. the electrics need to be real good and up to date.
our '61 bambi is standing tall
alclad is offline   Reply With Quote
Tankless Water Heater Lothlorian Water Heaters, Filters & Pumps 25 12-30-2007 11:30 AM
Tankless water heater GreatPumpkin Off Topic Forum 10 08-25-2006 04:28 PM
Tankless water heater dmadam Water Heaters, Filters & Pumps 26 01-19-2005 10:59 AM
Tankless water heater FC54 Water Heaters, Filters & Pumps 20 10-27-2004 04:18 PM
Tankless water heaters dmadam Water Heaters, Filters & Pumps 15 05-13-2004 10:22 AM
