03-16-2019, 06:30 PM
2016 30' Flying Cloud
Truckee
Water Heater works but no hot water at sink
OK first day out this year and I may not be able to continue.
Last year I had circuit board replaced on my 2018 FC 25 rear bedroom. Second time for this repair. I am using the AS for the first time since that repair.
Now the water heater has heated the water just fine but no hot water is getting to any of the fixtures (kitchen sink, bath sink,shower).
I have checked the shut of under the kitchen sink and it is open.
Water does flow from the sinks but a very low flow that never gets hot.
Any ideas? I do not know of any other shut offs between the water heater and the sinks.
Any help suggestions would be greatly appreciated.
03-16-2019, 06:33 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Check the bypass valve
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
03-16-2019, 06:35 PM
2002 25' Safari
Dewey
check the water heater bypass valves.
Richard
03-16-2019, 06:37 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
Sounds like the mixing valve on the water heater is stuck. You might try tapping on it but most likely it will have to be replaced.
They are readily available and relatively easy to replace.. I got a replacement from directly from JC within several days.
03-16-2019, 06:40 PM
Truckee
Sorry I didn’t mention the bypass valve
Yes I have checked the bypass valve and it is open. Even when I shut the by pass valve I get the same low flow cold water at the sinks and when I turn the bypass valve on there is no sound if water rushing into the tank which I would expect if I had drained off any of the water.
03-16-2019, 06:48 PM
Truckee
Mixing valve location
Is the mixing valve located just next to the bypass valve?
2002 25' Safari
Dewey
On my trailer there are three valves that make up the bypass system. There is an input valve for the cold water to the heater and a output valve for the hot water. There is also the bypass valve that allows water to go around the water heater.
Bypass mode
Input = closed
Output = closed
Bypass = open
Normal mode
Input = open
Output = open
Bypass = closed
Richard
03-16-2019, 07:06 PM
Truckee
I can’ Believe it it worked
Holy Cow! A Great Big Thanks to Hanz627. I tapped on the mixing valve ( more than a few times) and more water began to flow and it was also hot.
Looks like we are good to go.
You have saved an entire trip.
03-17-2019, 09:45 AM
2007 25' Safari FB SE
North/East
, New Jersey
Thiatt55.....It sounds to me to be a problem with the water heater bypass valves being in the wrong position. I had a similar problem with the water not flowing from the bathroom sink and found that there was an accumulation of a calcium looking material blocking the strainer located where the water flows out of the faucet. Its hard to believe that would happen on the other fixtures, but thought you may want to consider it. Good luck, lets us know what you find is causing the problem.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
03-17-2019, 12:58 PM
2017 27' Flying Cloud
Fernandina Beach
, FL
Mixing valve
If tapping on the mixing valve solved your hot water supply issue, the problem was likely due to gunk inside the valve. There is a tiny screen inside of the tank inlet that can clog up. If the problem returns, consider soaking the assembly in vinegar for a few hours. Its worked for me.
03-17-2019, 04:04 PM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
I had the same problem and same solution.....mixing valve on the water heater.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Hot Water Heater Works But No Hot Water
Althea |
Water Heaters, Filters & Pumps |
6 |
04-16-2016 09:45 AM |
AC just quit working and it's Hot Hot Hot!!!
SaabLover |
Furnaces, Heaters, Fireplaces & Air Conditioning |
9 |
07-27-2010 09:03 PM |
Hot water to sink but not tub?
ovrteakettle |
1 |
07-23-2009 01:07 AM |
Water heater works, but burn sounds change
Aluminumb |
0 |
10-21-2007 06:51 PM |
One sink, two sinks, red sink, blue sink?
Janet H |
General Interior Topics |
7 |
07-26-2006 06:17 PM |
