Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 04-09-2002, 01:39 AM   #1
FrankR
Profile:
Water heater work tool
For those needing to remove plugs from water heater, a wheel 3 or 4 way spinner wrench has a size to fit about all heaters. The 13/16 or 3/4 will remove most any plug because of leverage and very strong socket....A drained water heater cannot freeze. Frank
Water heater wind shield...Stays lited on the road.........
Name:	water heater wind shield.jpg
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 04-09-2002, 11:57 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Using the screen door gasket on the inside periphery of the water heater door also keeps the pilot light from blowing out. Much neater and alot cheaper, and takes 1 or 2 minutes. Road tested from Los Angeles to Orlando Florida wihout failing. However, when parked, the wind can still extinguish the pilot light. Andy
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 11:29 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
