Old 08-08-2015, 06:37 PM   #1
JSE
2008 22' Safari
Seattle , Washington
Water Heater won't stay on?
So I'm having some trouble with my water heater. It will light but immediately turns off. The pilot fires up, I get a flame but then it shuts off. I'm hearing a click when it shuts down.
Pressure, control board?
AS is a 2008 Safari Sport 22.
Any ideas?
Thanks in advance for any help.
JSE
JSE is offline   Reply With Quote
Old 08-11-2015, 08:48 AM   #2
1985 34' Excella
Durham , North Carolina
Same trouble with my 85 Excella...
bradleyoder is offline   Reply With Quote
Old 08-11-2015, 09:37 AM   #3
daveswenson's Avatar
2012 28' International
Issaquah , Washington
http://wbccicaravan.wbcci.net/files/...our-rv-iii.pdf
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-11-2015, 09:42 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I had similar. There are several possibilities of cause. What have you tried?
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-11-2015, 10:27 AM   #5
2004 28' International CCD
Cocoa , Florida
Same here on my 2004 28' international. It was the flame sensor/igniter. $25.86 on Amazon. VERY easy to replace. It will take you 60-90 seconds to replace. ��
Bhkh226 is offline   Reply With Quote
Old 08-12-2015, 03:41 AM   #6
1975 31' Sovereign
North Fort Myers , Florida
Thermocouple could be bad!
TLBIJOU is offline   Reply With Quote
Old 08-12-2015, 05:55 AM   #7
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Mine kept turning off after a short run time. Check your orifice, spiders sometime web across and block gas flow. Removed mine and held it up to light and you could see tiny threads. You wouldn't think it would be enough to hurt anything, but after removing heater runs great, better flame, and quieter. Something you could check.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 08-12-2015, 06:57 AM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Any ideas?
JSE
Old 08-12-2015, 08:13 AM   #9
JSE
2008 22' Safari
Thanks for all the replies everyone. Thanks Dave for the PDF. I need to read this front to back.
I think I will try the Sensor/Igniter first and then if no luck, the thermocoupler.
So far I have not have a lot of time to work on it but I have cleaned everything and made sure all connections are solid. Didn't seem to help. I still get about 1 -2 seconds of flame and then it goes out.
I'm hoping it's a an easy fix as mentioned above. I've got to the run by the AS tomorrow and get the right model number so I can order the igniter sensor. So maybe this weekend or next I'll be able to do the repair and see how it goes.
Thanks again everyone for the advise and help. Much appreciated and I will report back on the outcome.
JSE
Old 08-12-2015, 12:51 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ok.. I tried 'all the above' and finally replaced the 'igniter board'... with a "Dinosaur Board"... problem resolved.
Channing
WBCCI# 30676
Old 08-12-2015, 01:17 PM   #11
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Had similar issue with 2000 Bambi 19'. Cleaned and adjusted what I think is called the ignition tube. Seems to be working much better now. I live on some rural property and have a lot of wasps in the area. I found a small nest in water heater area.
curnes is offline   Reply With Quote
Old 08-12-2015, 02:35 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you are getting a "nesting" issue, plug up the holes on the outside door when NOT in use. A simple method is to open the WH door, drape a section of screen material over the opening then trap the screen by closing the door. You will
Probably want to cut a slot in the screen so the latch can easily protrude.
We have a "wasp screen" on the door and have had no issues. Wasps and spiders tend to like the "propane" odor and are drawn to its presence.
Just remember the 3 things needed for fire.. Air, fuel, ignition/heat source.
Channing
WBCCI# 30676
Old 08-14-2015, 10:47 PM   #13
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
sounds like a dirty igniter/flame sensor. clean with steel wool or replace. new board may fix it as it will have a different flame signal requirement
AlbertaBound is offline   Reply With Quote
Old 08-15-2015, 11:12 AM   #14
JSE
2008 22' Safari
Getting ready to order some parts. When you guys are saying igniter/flame sensor, are you talking about the spark probe? It's basically the pilot.
Grrr...water heater won't stay lit Diesel1 LP Gas, Piping, Tanks & Regulators 10 10-26-2012 08:29 AM
new water heater won't stay lit. Aage Water Heaters, Filters & Pumps 16 12-16-2010 04:14 PM
Gas Water Heater Won't Stay Lit somefun LP Gas, Piping, Tanks & Regulators 13 11-02-2010 04:32 PM
Water heater won't stay on Catman6 Water Heaters, Filters & Pumps 12 01-08-2010 10:36 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
