08-08-2015, 06:37 PM
2008 22' Safari
Seattle
Water Heater won't stay on?
So I'm having some trouble with my water heater. It will light but immediately turns off. The pilot fires up, I get a flame but then it shuts off. I'm hearing a click when it shuts down.
Pressure, control board?
AS is a 2008 Safari Sport 22.
Any ideas?
Thanks in advance for any help.
JSE
08-11-2015, 08:48 AM
1985 34' Excella
Durham
, North Carolina
Same trouble with my 85 Excella...
08-11-2015, 09:37 AM
2012 28' International
Olympia
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
08-11-2015, 09:42 AM
1999 34' Excella
Hillsboro
I had similar. There are several possibilities of cause. What have you tried?
Peace and Blessings..
Channing
WBCCI# 30676
08-11-2015, 10:27 AM
2004 28' International CCD
Cocoa
Same here on my 2004 28' international. It was the flame sensor/igniter. $25.86 on Amazon. VERY easy to replace. It will take you 60-90 seconds to replace.
08-12-2015, 03:41 AM
1975 31' Sovereign
North Fort Myers
Thermocouple could be bad!
08-12-2015, 05:55 AM
1993 33' Land Yacht
Midland
, Michigan
Mine kept turning off after a short run time. Check your orifice, spiders sometime web across and block gas flow. Removed mine and held it up to light and you could see tiny threads. You wouldn't think it would be enough to hurt anything, but after removing heater runs great, better flame, and quieter. Something you could check.
08-12-2015, 06:57 AM
1999 34' Excella
Hillsboro
Any ideas?
JSE
08-12-2015, 08:13 AM
2008 22' Safari
Seattle
Thanks for all the replies everyone. Thanks Dave for the PDF. I need to read this front to back.
I think I will try the Sensor/Igniter first and then if no luck, the thermocoupler.
So far I have not have a lot of time to work on it but I have cleaned everything and made sure all connections are solid. Didn't seem to help. I still get about 1 -2 seconds of flame and then it goes out.
I'm hoping it's a an easy fix as mentioned above. I've got to the run by the AS tomorrow and get the right model number so I can order the igniter sensor. So maybe this weekend or next I'll be able to do the repair and see how it goes.
Thanks again everyone for the advise and help. Much appreciated and I will report back on the outcome.
JSE
08-12-2015, 12:51 PM
1999 34' Excella
Hillsboro
Ok.. I tried 'all the above' and finally replaced the 'igniter board'... with a "Dinosaur Board"... problem resolved.
Channing
WBCCI# 30676
08-12-2015, 01:17 PM
2010 23' FB Flying Cloud
McMinnville
, Oregon
Had similar issue with 2000 Bambi 19'. Cleaned and adjusted what I think is called the ignition tube. Seems to be working much better now. I live on some rural property and have a lot of wasps in the area. I found a small nest in water heater area.
08-12-2015, 02:35 PM
1999 34' Excella
Hillsboro
If you are getting a "nesting" issue, plug up the holes on the outside door when NOT in use. A simple method is to open the WH door, drape a section of screen material over the opening then trap the screen by closing the door. You will
Probably want to cut a slot in the screen so the latch can easily protrude.
We have a "wasp screen" on the door and have had no issues. Wasps and spiders tend to like the "propane" odor and are drawn to its presence.
Just remember the 3 things needed for fire.. Air, fuel, ignition/heat source.
Channing
WBCCI# 30676
08-14-2015, 10:47 PM
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose
, Alberta
sounds like a dirty igniter/flame sensor. clean with steel wool or replace. new board may fix it as it will have a different flame signal requirement
08-15-2015, 11:12 AM
2008 22' Safari
Seattle
Getting ready to order some parts. When you guys are saying igniter/flame sensor, are you talking about the spark probe? It's basically the pilot.
08-17-2015, 03:05 PM
1999 34' Excella
Hillsboro
It is the electronic board called UIB (universal igniter board). I got mine from this guy. Spoke to directly on phone! Helped isolate and ensure this was the issue!... R & G Electronic Home
Channing
WBCCI# 30676
08-18-2015, 08:31 AM
2008 22' Safari
Seattle
Thanks. I have a spark probe I'm going to try this weekend and if that does not do the trick, I will call R&G and order a new igniter board. Fingers are crossed but regardless, I'm learning about the heater system.
JSE
08-18-2015, 09:17 AM
2016 28' Pendleton
Scottsdale
Hi from AZ. . . as my old man frequently reminded me, do the easy stuff first, Dummy. Clean tube & replace thermocouple (cheaper than board) It's worked for me in the past., regards, Craig
WBCCI 2851,4CU
08-18-2015, 09:50 AM
Walnut Creek
It's not the problem most of you are chasing, but when we first got the AS, our heater would not run after initial startup. Symptoms included low water pressure and immediate shutdown in electric or gas mode. The unit had been winterized and the isolation valve was not returned to the open position at commissioning. Since the valve is hidden behind drawers, it took some investigation to find that it was still closed. Pat
09-20-2015, 07:07 AM
1964 28' Ambassador
Hot spring
, Arkansas
I want to replace my water heater with a tankless anyone have any thoughts on that.? I have a 1964 Ambassador Land yacht and I thought that it's over 50 years old scares me.
09-20-2015, 09:11 AM
1999 34' Excella
Hillsboro
If you can find one that fits the dimensions, no reason not to replace with one... especially if you can find a 'marine' version which can handle the movement you will have towing...
Channing
WBCCI# 30676
